high power tube amp kits using KT120s or KT150s?
Old 27th June 2020, 09:54 PM   #31
wg_ski is online now wg_ski  United States
No real need to go to a custom OPT - if the Hammonds are good enough for you. The 1650W will do it. I’m driving mine with 6 6550’s (Tung-sol, the ones that look like the old Sovtek KT88) because they are common tubes, avoiding the long term availability issues of KT150’s or sweep tubes. You could just as easily use EL34’s even, but it would take 8 or 10 of them. That trafo is heavy - bigger than the power transformer in the old PV CS-800. And you can get them at Digikey.
5k a channel? No way. Just the big stuff cost me $1k per channel - you would at LEAST add a zero, or more, to have someone build this for you.
Old 27th June 2020, 10:49 PM   #32
OscarS is online now OscarS  United States
Originally Posted by CaterpilarSK View Post
just a friendly reminder...Just forget about high power tube stuff for a second. Think of the problems and the costs. I get it you might be rich but you cant pay physics to not apply to you.
Firs of all 150W with a KT150/120. There is not a lot of factory amplifier that properly utilise the tubes let alone kits.
If you want that power level you seriously need to look into the maths and theory behind. No way round arround. Assuming you want to build it. This aint a TDA or a semiconductor jobbie.
I personally think its well worth it to look into it. I myself built the Mullard 5-20W amplifier ground up designed the PCBs and went on to design something proper with KT88 (80or so watts) and its been a year and I am still not done with it. Eventually I want to build with KT150s but those tubes are a challenge. As mentioned before it would be A LOT smarter to go with two monoblocks. The weight will already be monstrous. The power transformer needs to be very beefy to a custom voltage, the output transformer needs to be a custom job aswell, wound to impedances to match the currents those KT150s can deliver at their max allowed voltage. Its not as simple as buy a kit and snot the solderpoint together and youre done. You dont quite realise the design challenges high power vacuum tube amplifier impose. Impracticalities, and the shear ridicilousness (sorry for the spelling) what a 150W KT150 amp would be (and no 150 doesnt equape to 150W). You would need to run a quad of them for each channel. If you got the money I just recommend you ask a credible manufacturer to build something for you to request so you get a properly designed amplifier for what you want. For the cost of course.. Prepare yourself to spend 5K on each channel.
Just to think of the shear current that would run trough the windings of the transformers 4 ohm output makes my spidey senses tingle enough to realise it would be a 25kg output transformer..thats just the OTP..
Thanks for your input. The whole KT-thing was just an initial impression I got from the basic research I did as to what tubes were capable of what. I guess you can say I've learned they're not a necessity. I'm not rich by any stretch of the imagination, otherwise I'd have what I want already. I'm looking for a good value in a high power tube amp, hence the search for a good kit. Two monoblocks are exactly what I'm looking at with the M-125's from Bob @ VTA.
Old 28th June 2020, 05:24 AM   #33
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
Diabolical Artificer's Avatar
I built these, see pics, more here - 120w PP UL monoblocks. 6 EL34's, overwound mains toroid tfmr, 1100u reservoir caps, Hammond 1650TA OP's, protection circuit, etc, etc. They took a long time to build though. Sorry not available as a kit but I can send you the schematic's though.
Andy.
Old 28th June 2020, 09:03 AM   #34
Kjeldsen is offline Kjeldsen  Denmark
Maybe you should look at bass head kits. If you are lucky they will also be suitable for hifi
Amp-Kit Plexi 150W Bass Guitar
http://kjeldsensforbindelser.dk
Old 28th June 2020, 10:26 AM   #35
russc is offline russc  England
Originally Posted by OscarS View Post
I need lots of power to re-create what it sounds/feels like to be at a death/grindcore metal concert.
HiFi is not the OPs objective.
Don't forget to budget for a room with crap acoustics and invite lots of sweaty friends around to listen.
On a serious note, please take care of your hearing.
Old 28th June 2020, 11:46 AM   #36
duncan2 is offline duncan2  United Kingdom
I am glad you mentioned that Russc that is something I advised many people to watch out for on a very well known UK public help website .
I have all the American data on hearing loss due to insanely loud movies to which very many of the UK public complained about vigorously .
Once those nerves are dead --that's it !
Ear bleeds watching movies and the movie theater refusing to tone down the racket .
It takes many years to feel the full effect of this --does anybody fancy having a hole drilled in your skull and wires attached directly to your brain ?
Check out the number of US children with hearing aids.
Old 28th June 2020, 02:15 PM   #37
Not looking to "take chances", thank you.
Old 28th June 2020, 02:17 PM   #38
Andy.
Thanks for your input Andy, but the M-125s are available as a kit, so it wouldn't make sense going this route.
Old 28th June 2020, 04:38 PM   #39
You can write to them and ask. I know Marshall have som guitar power amps, that are good for hifi as well.
high power tube amp kits using KT120s or KT150s?Hide this!Advertise here!
High Power Tube Amplifier comnoz Tubes / Valves 51 4th February 2018 06:16 PM
High-end Tube amp kits (all-included) regiregi22 Tubes / Valves 40 28th April 2013 05:51 AM
DIY High Power Car Tube Amp wilkes5 Tubes / Valves 32 7th November 2012 07:41 AM
Simple SE with KT120s oddboy Tubelab 9 14th March 2011 04:46 AM
High Power Tube Car Amp plate_follower Car Audio 6 28th October 2006 08:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
