Ordering from Justradios.com
Old 6th July 2020, 01:06 PM   #181
Fjellreven is offline Fjellreven
Yeah but is my soldering good enough
YouTube
Go into the video at 5 minutes 25 seconds
Is my soldering better then his, i want my solder joints to last as Long as possible.
Old 6th July 2020, 01:13 PM   #182
duncan2 is offline duncan2  United Kingdom
Sorry Fjellreven cant access YouTube I have it blocked due to tracking.
I have repaired radios from the 1920,s and have never needed to go round every soldered connection reflowing them just the ones that looked bad.
Because of the heat generated in power amps this is more of an issue but not in tube radios .
Old 6th July 2020, 03:13 PM   #183
Well i am very thankfull Duncan and all the other for you're help and here is little tip maybe you already know this but before you buy a radio or a speaker where you can't easily remove the protection try the light trick, it can't tell you if its rubbing or if the voice coil is shorted but it can tell you if there are major DAMAGE to the cone.
Old 6th July 2020, 03:16 PM   #184
Opps the picture wont show but here they are.
Old 7th July 2020, 11:23 AM   #185
Well ops something happened i managed to burn a pad. is this an acceptable solution? I am aware i used to much heat im turning it down.
Old 7th July 2020, 11:24 AM   #186
Yeah im aware that doesnt look that great but im not used to soldering in such a cramped Space.
  Reply to this post
Ordering from Justradios.comHide this!Advertise here!
Justradios - Recent email problem VictoriaGuy Parts 0 26th February 2019 12:35 AM
Anyone ordering from THEL? Nisbeth Parts 0 6th April 2007 09:39 PM
Ordering a Charlize? onehotchili Class D 2 26th May 2006 06:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
