Ordering from Justradios.com
Old 4th July 2020, 06:19 PM   #151
Fjellreven is offline Fjellreven
I am using the big film capacitor as a reservoir cap.
Old 4th July 2020, 06:37 PM   #152
Also can i Mount those 5 uf capacitors upside down.there is very limited Space on the board.
Old 4th July 2020, 06:41 PM   #153
duncan2 is offline duncan2  United Kingdom
Yes you can.
Just make sure the HT+/power supply doesn't cross over the tuner circuit ,keep the power supply away from the aerial input.
Old 4th July 2020, 06:47 PM   #154
Also i was wrong the 17 uf doesnt go to the speaker transformer it goes to a wire straight to the board.
Old 4th July 2020, 11:18 PM   #155
Hey is it okay to Mount electrolytics like this i know this looks wierd buy its replacing a big multisection capacitor.
Old 5th July 2020, 07:26 AM   #156
Yes its okay you are replacing them directly into the soldered copper PCB holes occupied by the old capacitor .
Keep the pins soldered as close as you can to the board.
Old 5th July 2020, 09:44 AM   #157
Is IT okay that the capacitor to the left is a little tilted?
Old 5th July 2020, 11:39 AM   #158
Yes that's alright , you are working on the power supply , it wouldn't be alright if it was the RF section.
Old 5th July 2020, 01:28 PM   #159
TG is offline TG  Ukraine
It actually depends - some capacitors should be mounted strictly vertically.
But most of those are big snap-in or screw terminal ones. For smaller PCB caps (especially the ones with "scored" aluminium top plate) mounting position is not that important.
Old 5th July 2020, 02:46 PM   #160
Hey is colored Steel wire good enough for extending capacitor leeds
Ordering from Justradios.comHide this!Advertise here!
Justradios - Recent email problem VictoriaGuy Parts 0 26th February 2019 12:35 AM
Anyone ordering from THEL? Nisbeth Parts 0 6th April 2007 09:39 PM
Ordering a Charlize? onehotchili Class D 2 26th May 2006 06:58 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
