Volume at the output of preamplifier matching transformer
Old 23rd May 2020, 03:58 PM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Originally Posted by Schmitz77 View Post
Its not any longer a balanced output
It is balanced. Only i/p o/p impedance is not constant. Does it matter?
Old 24th May 2020, 04:11 AM   #12
PRR is offline PRR  United States
PRR's Avatar
It will pass audio and is adjustable.
If we wanted "perfect amplification" we would not be using tubes and iron. Clearly this is an "effect" used to change sound. Flaws are good.
Old 24th May 2020, 06:05 AM   #13
Glass_painter is offline Glass_painter  Israel
Thank you all for the information.
My concern was not to short the output transformer which is never a good thing.
how would this circuit work when the pot is shorting the OP transformer?
Thanks again
Glass Painter
Old 24th May 2020, 06:46 AM   #14
analog_sa's Avatar
Did you read what you were told above? Move the pot to the right side of the 300ohm resistors and all will be well. For the record, shorting the transformer won't blow anything.
Old 24th May 2020, 08:01 AM   #15
Schmitz77 is offline Schmitz77  Germany
Maybe you'r correct. My fault.
Volume at the output of preamplifier matching transformerHide this!Advertise here!
Matching 16 ohm loudspeaker into 8 ohm output transformer: can i do any modification? ygg-it Tubes / Valves 6 10th December 2014 02:48 PM
Output transformer impedance matching cspirou Tubes / Valves 10 11th November 2014 02:06 AM
Newbie question about output transformer to speaker matching rss388 Tubes / Valves 5 15th May 2011 08:05 AM
Output transformer matching to active device driving it macrohenry Solid State 3 17th August 2007 06:51 AM
SE Output Transformer Matching ttan98 Tubes / Valves 2 27th April 2006 04:28 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
