EL84 triode wired bias and operating points
Thread Tools
Old 22nd May 2020, 08:45 PM   #1
operater is offline operater
Default EL84 triode wired bias and operating points
Hi all, oprtr back.
I'd like to discuss a concrete example on EL84 operating points in triode vs pentode mode:
Why is it that all of the spec sheets insist that when those babies are triode operated that Rk should be higher and thus the bias lower. Aren't the current swings supposed to be lower and thus safer when running the tubes in class A, triode or not.
I have measured both plate and grid current and dissipation with the tubes cathode biased at 98% and it was perfect. I guess everyone worries about the screen grid, but even at max plate bias the screen was well below the 2W dissipation with no swings.
VS
What am I missing
Old 22nd May 2020, 09:21 PM   #2
Ketje is offline Ketje  Belgium
Ketje's Avatar
In SE the current can swing from 0 to Ibias to 2xIbais.
As a triode the tube can't get as much max current as in pentode.So it's no use turning up the bias that high.
Mona
Old 22nd May 2020, 10:02 PM   #3
Mona
I always thought that cathode biased class A (triode or not) was always at max amplitude and thus had no dramatic swings in current. Hence we never bias AB/PP above 70% and I always saw cathode biased class A as safe all the way up to 100%
Old 23rd May 2020, 12:42 AM   #4
20to20 is offline 20to20  United States
The data sheets generally show snapshot examples of performance, not necessarily recommended operating points. There is a difference in the load impedance shown between those two examples, also. The bias point is @9.5v for the triode example. Just snapshots.
Old 23rd May 2020, 05:45 AM   #5
PRR is offline PRR  United States
PRR's Avatar
You are thinking of DC current. The AC/audio current swings wildly. {as Mona says} Ideally from zero to twice DC. In a pentode, about 20% to 180%. In a triode, rarely past 50% to 150%. And since the max current is less in triode, the idle current is selected lower for bets total performance.
The datasheet was intended to sell the tube. Small-signal tubes with a wide range of possible uses, the "Conditions" might be show-off. (In audio we never run 12AT7 per datasheet, we never use that much current, but a TV tuner will.) Tubes intended for audio power amps, the datasheet conditions are always excellent starting points; if they weren't, designers would not be inspired to use (and buy) that tube. (With a few marketing conflicts: for historical reasons when 6L6 ratings went up the Conditions were mostly copied-over, etc.)
Old 23rd May 2020, 08:02 AM   #6
6A3sUMMER is offline 6A3sUMMER  United States
EL84:
With a good output transformer, triode mode may be lower power.
But the frequency response and damping factor Are reasonable, even without negative feedback.
With a good output transformer, pentode mode may have higher power.
But the frequency response and damping factor are Not reasonable, so the circuit needs negative feedback for those to be reasonable.
  Reply to this post
EL84 triode wired bias and operating pointsHide this!Advertise here!
Thread Tools
No DC Operating Points polsol Software Tools 9 26th October 2016 04:47 AM
EL84 fixed bias PP Triode DrewP Tubes / Valves 23 24th November 2013 08:17 PM
GU-50 in Single-Ended Triode Configuration - What bias points? quikie22 Tubes / Valves 87 30th January 2013 09:00 PM
PSE 2a3 operating points? andyjevans Tubes / Valves 4 26th May 2012 03:27 PM
Operating points for #37 triode Burnedfingers Tubes / Valves 1 27th November 2003 05:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
