And, you also get the advantage that all the magnetic fields of each magnetic device is conducted to all the other magnetic devices. Hmmm, Buzz, squeal.
Exactly! That’s why I use mainly 4 mm thick aluminum and sometimes 3 mm thick for smaller pieces.
Regards, Gerrit
It's alive!
I finish 1 channel, measured 33W output power before limitation.
I used ECF82 instead 7199, set around 85V on anode and balance with trimmer on g2 of pentode (thanks for hint). Now I need do the same, but also with painting, for the 2nd channel.
I have the same Dynamutt board in my ST-70 redux and it's great. I agree, if you can source the boards (I could send you the documentation) do it.Good question.
With so much better front ends than the ST70 i see little point. My ST70s (both broken) got turned into the 1st DYnaMutt and it is a temendous amp. You would likely have to directly contatc Gregg the Geek to get more detailed info.
dave
I contacted them a few months ago, apparently him and his partner split and the partner has the board layouts.
I purchased several boards from them 5 or so years ago, I lost track of where I stored them!
- Tubes / Valves
- Edgar ST-70 new construction
