Oh no...not another Baby Huey EL84 build.
Old 28th May 2020, 10:29 AM   #151
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I would like to take advantage of using the 6N2P -EV and 6P14P-EV as well as
12ax7 and EL84 configurations by installing toggle switches if that is viable.
Toggle switches are viable. Just use them in lieu of the jumper. And I use the 6P14-EV. Great tubes. They can be used as is.
http://basaudio.wordpress.com
Old 28th May 2020, 10:32 AM   #152
I have been wondering about ordering another psu board.
One is good enough (since there is additional smoothing option on the baby huey el84 boards. (Just don't populate the bias part of it...it has an error in it..and you don't need it since it is already on the bhel84 pcb boards) And in that case the choke you mentioned is perfect.
Old 28th May 2020, 12:23 PM   #153
eldarvanyar is offline eldarvanyar  United Kingdom
eldarvanyar's Avatar
Default Oh no...not another Baby Huey EL84 build.
Thanks Bas
So just to confirm as we have 3 chokes mentioned
The 10h 500ma is overkill and not needed
That leaves
The TDS 10/250 10h 250ma
The TDS 12/200 12h 200ma
Which one is the best to go for and why?
Thank you again for your time and patience.
Lee
Old 28th May 2020, 12:41 PM   #154
Hi Lee,
If you use the psu board. Get the one big choke.
If you are using the boards only. Use Either of the two. You won't be able to tell the difference between 10 or 12. If all it took was to get the biggest capacitance or largest inductance it would be easy. But look at a psu as a stream. The more pebbles in the stream the more swirls, eddies and turbulence you get. Do things as simple as possible but you have to do enough.
So I would suggest to use the psu board. And then just use the on big boatanchor choke. .
Then on the board you could use a resistor where the chokes are supposed to go...to tweak your voltage.
Old 28th May 2020, 02:37 PM   #155
Francois G is offline Francois G  United States
Originally Posted by eldarvanyar View Post
Thanks Bas
That leaves
Lee
Get TDS 10/250 at 250 ma.
Old 30th May 2020, 08:48 PM   #156
Are you still searching ?
Found it today!!! Under my bed...(where I looked twice before!)
Old 31st May 2020, 12:49 AM   #157
Congratulations and two cheers.
What are you going to build with them now that you have a pair again?
Old 31st May 2020, 09:56 AM   #158
Don't know yet...
Old Yesterday, 05:53 PM   #159
snapper is offline snapper  Germany
Originally Posted by Bas Horneman View Post
It's a Maida copy of Tom's but someone made some pcb's himself.
seems to be an extended version, are there any information / empty pcb to buy?
I also know this version from your countryman! --> T-reg HV regulator | Linear Audio NL
Old Today, 04:09 AM   #160
It's a 21st century maida with the thingy (Morgan Jnones) Not sure the thingy is useful. The info that it is exactly as described on diyaudio in the earlier schematics. Last time I spoke he was out of boards. If you just need one. I can send it to you partly populated.
Oh no...not another Baby Huey EL84 build.Hide this!Advertise here!
EL84 Amp - Baby Huey gingertube Tubes / Valves 2338 31st May 2020 02:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
