Oh no...not another Baby Huey EL84 build.
Old 21st May 2020, 09:58 PM   #131
eldarvanyar is offline eldarvanyar  United Kingdom
eldarvanyar's Avatar
Originally Posted by Bas Horneman View Post
6n2p-EV and 6p14p-EV
Hi Bas,
Did you have to wire the differently for the Russian Valves and make any other adjustments regarding resistors etc
I have a stack of 6n1p-EV and 6n2p-EV that I bought last year
According to my notes on my iPhone they have to be at 6.3v
How to use 6N1P and 6N2P Russian tube ― Hi-End vacuum tubes, sockets, capacitors, nixie. Retail and wholesale to worldwide.
I would be happy to be able to use them in the BH - I know on some diy builds I have read people have wired in a switch to enable an easy swap between 12ax7 and 6n1p
Can you say what difference you have found
Thanks again
Lee
Old 21st May 2020, 10:58 PM   #132
Bas Horneman is online now Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Lee,
The groupbuy pcb's have a pin where you can set that.....I forgot the name..you see it often in older computers.
I've not switched between 12ax7 and 6n2p yet.
Kind regards,
Bas
http://basaudio.wordpress.com
Old 22nd May 2020, 05:31 AM   #133
snapper is offline snapper  Germany
close jumper for ECC83 1-2, for 6N2P 2-3
Old 23rd May 2020, 12:10 AM   #134
Hi Snapper,
Could this be wired with a toggle switch to make tube rolling easier?
The other option would be jumpers like in PCs as mentioned by Baz.
How do I wire or set for 6n2p valves?
Lee
Old 23rd May 2020, 03:03 AM   #135
Francois G is offline Francois G  United States
snapper already answered your question.
Old 23rd May 2020, 09:20 AM   #136
You ordered the board right Lee? In that case use a jumper. See the pcb schematic for which position is which. 1-2 is for 12ax7. 2 and 3 6n2p
Baby Huey PP EL84 amplifier
Old 23rd May 2020, 10:08 AM   #137
Hi Bas,
Yes I have ordered the boards and waiting for delivery which is delayed due to COVID-19.
Can you post a direct link to the BH EL84 BOM as I cannot seem to find it.
I am thinking through the project at the moment. I sent two emails to the Dutch guy regarding the same output transformers as you but still not had any reply.
I am wondering about Audionote EL84 Output Transformers which are similar in cost and weigh a hefty 4kg. They are used on the OTO PP Amp.
The Toroidyís look very good as well particularly in their covers. My understanding is that the better the output transformers the better the sound. I donít want to hijack your thread and can start a new one if that would be better.
Lee
Old 23rd May 2020, 11:43 AM   #138
BOM EL34 and EL84 Baby Huey-12-2018
Old 23rd May 2020, 12:21 PM   #139
I don’t want to hijack your thread and can start a new one if that would be better
No it's fine. I don't see it as my thread. It's all about communicating with each other about this fine hobby of ours. You are welcome to ask.
Here is the BOM I used on mouser. It is not a complete BOM. But contains some parts which are not typically in my house like the semiconductors etc. The rest are easy to get locally for better prices. As mouser is not cheap...
Mouser Electronics Inc. Nederland
And for the rest see the BOM that snapper linked to.
Old 23rd May 2020, 01:48 PM   #140
Go local for sure. Especially since Vlaartronics are not replying to you.
Oh no...not another Baby Huey EL84 build.Hide this!Advertise here!
EL84 Amp - Baby Huey gingertube Tubes / Valves 2375 3rd August 2020 12:10 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
