Problems with London City Bulldog / Ashton VP100 tube amp
Old 28th March 2020, 07:23 PM   #21
Ketje is offline Ketje  Belgium
Ketje's Avatar
Check R94.Probably much to high.
Mona
Old 28th March 2020, 07:27 PM   #22
Ricotjuh is offline Ricotjuh
Just done and it turns out to be infinitely high. So this is broken. I'm going to replace it. Do I have to worry about C59 ?!
Old 28th March 2020, 07:56 PM   #23
Yes it worked. That was the problem. Now a neat signal comes out and volume is also at the right level again. Hum has also disappeared.
Do I still have to think about how this resistor died? (Didn't look black)
Or was this just a bad luck?
Old 28th March 2020, 08:51 PM   #24
Ketje's Avatar
With a 12AX7 in there the dissipation in the anode resistors is less then 100mW but with the 12AT7 it goes up to 400mW.If those resistors are ment for the AX they overheat with the AT.
Take 2W resistors for the two anode resistors.
Mona
Old 28th March 2020, 11:12 PM   #25
And if I replace the AT for an AX, would that also be a good solution? And then I don't have to change any other components?
Or what would be a good reason to place a 12AT7 in this position? That is not entirely clear to me.
Old 29th March 2020, 09:26 AM   #26
Ketje's Avatar
Doesn't make much difference for this amp.
I prefere the AT in this position, it has better drive power.But to take full advantage of that tube you have to change more then two resistances.
Mona
Old 30th March 2020, 08:43 PM   #27
Originally Posted by Ketje View Post
Here some voltages you can check.
Mona
Can you tell me how you calculated these values? These now indeed correspond with reality. I also try to calculate it but I can't. I may overlook something, but hopefully you can help me.
Old 31st March 2020, 10:02 AM   #28
Ketje's Avatar
To find those voltages you have to draw a loadline.The load is what comes between the supply (444V) and ground for the tube.
Starting from ground there is R99, R98, R93, R94//R95 and R96.
4k7+10k+0k47+45k+4k7=~65k (I am lazy, like to round-off )
The 45k is 100k//82k.
Since this load is used by the two triodes each sees 130k.
Now we go back to post#14 where you see the loadline 440V-130k and a line for where you get with a cathode resistance of 1k (also double R93).
The intersection of those two lines gives the working point, about Va=150V,Ia=2mA and Vg=-2V.
The current for most resistors is 4mA exept the anode resistors, one (100k) a bit less then 2mA the other (82k) a bit more.
Nowing the current it's easy to find the voltages now (thanks mr.Ohm).
There is a little error because R96 is also used by another circuit giving extra voltage drop, but who cares
Mona
Old 31st March 2020, 10:19 PM   #29
Mona
Thanks for the clear explanation. I can move forward with this! Top
Problems with London City Bulldog / Ashton VP100 tube ampHide this!Advertise here!
FS: London UK. Loads of parts for tube and ss. Priced to go. andyjevans Swap Meet 0 17th February 2020 05:37 PM
SS amp with tube amp problems Duke58 Solid State 3 26th April 2018 09:22 AM
Complete newbie for Tube Audio in London! repeatclicks Introductions 1 19th November 2009 08:12 AM
jensen "bulldog" drivers? Nanook Full Range 1 15th February 2005 09:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
