Headphone amplifier output capacitor safety
Headphone amplifier output capacitor safety Please consider donating to help us continue to serve you.
Old 14th February 2020, 08:22 PM   #11
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Baudouin's schematic is just fine. Could I also recommend a amp fast-blow fuse in line, too? That way, if the 12 V Zener stack is conducting too aggressively on a blown capacitor, well … the fuse will also pop. Probably saving the Zeners, and debugging them, and all that.
⋅-⋅-⋅ Just saying, ⋅-⋅-⋅
⋅-=≡ GoatGuy ✓ ≡=-⋅
Burnished unicorn horn circuit-design only goes so far. When the magic falls flat, it is best to rely on solid maths. Just Saying... GG
Old 14th February 2020, 08:24 PM   #12
monty78pig is online now monty78pig  England
monty78pig's Avatar
I doubt you'll be able to get half an Amp out of the cathode of most triodes... Perhaps a fusible resistor? But that of course comes with the penalty of reducing damping factor.
http://www.objectivesounds.co.uk/ With perfect linearity, it is impossible to go off on a tangent.
Old 14th February 2020, 11:00 PM   #13
Ti83 is offline Ti83  United States
The zener clippp does look nice. Thanks guys.
Old 14th February 2020, 11:07 PM   #14
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
Originally Posted by monty78pig View Post
Cathode followers always power up very nicely due to the inherent delay in conduction as the filaments warm up.
Yes, it's this. The question here is not how to completely eliminate any possible DC offset from ever coming out of the headphone jack, it's whether this is an actual issue.
In practice that 30uF cap probably isn't big enough, and at 100uF you'll need to build the circuit and fine tune the value of that 10K resistor at the output to pull down the voltage spike sufficiently.
Headphone amplifier output capacitor safetyHide this!Advertise here!
Headphone output on push-pull amplifier? ThyDntWntMusic Headphone Systems 8 12th September 2015 01:46 PM
safety with high voltage input capacitor ? Bigun Tubes / Valves 10 19th April 2014 02:34 AM
Midgard, a low distortion Lateral FET output Headphone Amplifier Neutrality Headphone Systems 8 14th December 2012 08:31 PM
Newbie: Resistor and Capacitor Types for Aikido Headphone Amplifier DrDeville Headphone Systems 7 9th December 2006 05:10 PM
Safety when testing headphone amp for muso's loonatron Headphone Systems 8 20th March 2005 05:07 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
