Strange graph in PSUD2 (oscillation?)
Strange graph in PSUD2 (oscillation?) Please consider donating to help us continue to serve you.
Old 13th February 2020, 08:27 PM   #1
force of 1/2 is offline force of 1/2  United States
Default Strange graph in PSUD2 (oscillation?)
Hi Everyone,
I am away from my soldering iron for a while, but I have my computer with me, so I have been modeling different power supply options in PSUD2 for a couple projects waiting back home.
There is a recurring theme to these models: strange "V" shaped lines or sometimes slopes for the voltage graphs. These show up if I chose a delay for the sample period. The images below were sampled after a delay of 120 seconds.
Is this a sign of oscillation in the power supply?
see the two attached images for a phono preamp. One is the power supply as suggested on the schematic, and the second is a model of a PS based on parts in my scrap box.
Old 13th February 2020, 08:31 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
The difference in voltage between top and bottom of V is so small it is irrelevant.
2020 versions of PCBCAD51, PCBCAD360 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 13th February 2020, 08:50 PM   #3
Thanks Nigelwright7557,
I appreciate the response. This is what I felt, too, but some configurations brought up straight lines-- or bars really-- showing just the ripple.
The modulation (bending of the bar) of the voltage plot shown above seemed a little odd, but I couldn't quite decide if it was just an anomaly of PSUD2, or something I should try to iron out. (or as you suggest, not to worry because we are only looking a a few micro volts difference).
The graphs plotted with no delay on the sample period look nice and smooth. No ringing.
Old 13th February 2020, 09:03 PM   #4
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
You're like down in nanovolt territory, well below self noise for most tubes.
Old 14th February 2020, 10:09 AM   #5
Jazid is offline Jazid  United Kingdom
At a guess in the second pic. if you extended the time window to 100-140 seconds you'll see an oscillation and slight increase in voltage as the PSU caps continue to charge, I don't think it's completely reached a steady state yet with that humongous iron and capacitance downstream of the load. Mind you the ripple is pretty much non-existent.
Might I ask if all this is stuff in the parts bin, because otherwise with the cost of the iron chosen, caps with 2ohm ESR are an anomaly since this can easily be improved for small bucks?
Old 14th February 2020, 02:16 PM   #6
Hi Jazid,
Thanks for your response.
I will extend the time and see what it looks like. Didn't know I could make the sample period that long, actually.
The second one with the thin red "V" represents parts in the spares box. Leftovers from various projects.
But for small bucks, I don't mind placing a small order.
What did you have in mind?
Quick expalnation:
(the 2ohm caps in the first chart are just the PSUD2 default. The ESR in the second chart are rounded off from spec sheets)
(The schematics represent the whole chain of filtering including the inter-stage decoupling. The basic DC supply ends after the second choke. I was just seeing if I could get away with using the 3uf caps later in the chain, or if the schematic's suggestion of 47uf was necessary to achieve low ripple.)
Old 14th February 2020, 02:33 PM   #7
Here are screen shots 140-170 seconds out, 170-200 seconds, and 200-230
Old 14th February 2020, 02:53 PM   #8
Ti83 is offline Ti83  United States
My estimation of what you are observing is a commonality to many, many numerical modeling systems. Especially when you are considering a transient, non-linear solver. Given the non-linear mathematics introduced by magnetics, a transient solution to that non-linear system of equations is very likely to employ an iterative relaxation method, such as Point-Jacobi or Gauss-Seidel, to determine the "result" at each time step. The tolerance to which that iterative solver converges is finite and there is a tradeoff between accuracy and the number of iterations required. In this case what you may be observing is this inaccuracy between successive solution steps.
I don't have any visibility into PSU-DII but lTspice gives little messages at the bottom of the screen about corrective alterations to the solver's parameters. My quickest speculation is summarized as: numerical solution techniques retain small amounts of error, which can be visible in adjacent time steps.
Old 15th February 2020, 01:59 AM   #9
PRR is offline PRR  United States
PRR's Avatar
The physical system CAN'T oscillate (assuming everything ideal-- WiFi and other crap will throw oscillations into any real build).
You are looking MUCH too close. Nothing in here individually moves slower than a second. Yes, if you zoom-in to NANOvolts, you can see it is "still climbing" at 30 seconds-- the rise extends to infinity. This comes to the old joke about the mathematician and the engineer. #2
The program is approximating a continuous system with numbers of limited precision. There WILL be round-off errors. Each one small, but after a zillion iterations they can start to show at the NanoVolt level. Long repeated computations CAN "oscillate" if they get between a round-up and a round-down point. Your latest shows that this complicated algorithm can "jump" if rounding crosses some critical point. My uncle could explain this all to you (you could not afford his rates).
This is "just an amplifier". You don't need all that precision. 270V or 290V makes no difference to us. Sub-mV ripple is usually good.
Current-sources are *always* problematic in this type of simulation. (They should be current limiters but PSUD's current-things seem to source power, which "fights" the power coming from the line.) Use a 71k resistor instead.
And 3.8mA is mighty darn small to justify a choke, especially in this world of cheap electrolytics. Another stage of R-C filter will get you to the same point, in less space and much less cost.
Old 15th February 2020, 03:59 PM   #10
Thanks everybody for you responses!
Ti83: Yes. this makes sense. This is similar to my first intuition about the graphs.
PRR: I enjoyed the jokes. Thanks. Point taken.
Strange graph in PSUD2 (oscillation?)Hide this!Advertise here!
PSUD2 help mr ed Power Supplies 4 19th May 2019 02:38 PM
ESP P101 using rod pcb very strange oscillation issue brunogiovs Solid State 12 9th March 2016 07:13 AM
PSUD2 on Mac Doug in Indy Software Tools 5 29th August 2015 12:58 PM
psud2 merlin el mago Power Supplies 0 12th December 2012 07:13 PM
when using PSUD2, do you... jarthel Tubes / Valves 13 15th August 2006 03:08 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
