riaa amplifier
riaa amplifier
Old 15th February 2020, 01:42 AM   #11
gofar99 is offline gofar99  United States
gofar99's Avatar
The values above are typical however it should be noted that R5 is dependent on the tube used for V1. It will usually be about 92K minus the Ra of the tube (with the shown caps of 30nf and 10nf). So with the tubes shown 70K is a reasonable value. R6 does fit into the calculations and ought to be the 470K value. Often you will see a grid stopper resistor on V2 as well. Values I have seen are in the 4.7K to 22K range. I would suggest a cathode follower be added if the output cables are of any significant length or the input impedance of the following stage is less than about 5K. The linearity of the second SRPP will not be as good below that loading.
Good Listening
Bruce
Old 15th February 2020, 05:39 AM   #12
ioannidis is offline ioannidis
as far i can understand from these simulations the response in red color is the <flatter> one. However i will try both versions (in the second version i will use R6= 470KΩ as gofar99 suggested) and measure the total preamp response using the REW software and a 40db-attenuator at the input.
It is a little strange that the blue curve, using same values as the Groovewatt amp does, is not as good as the red one (or at least it seems to be) because of the roll off at lower frequencies. Maybe in this circuit the tubes have an effect on the overall response? or it can be due to the 0.22uF capacitror in the first stage?
Old 15th February 2020, 07:10 AM   #13
PRR is offline PRR  United States
PRR's Avatar
The tube stages depend on the tube. I see three different types in the drawing in post #1. Using 6DJ8 I get 680 Ohms, using 12AT7 I get 3k. Facing a load 30k-57k and up, the difference is small, but about the size of the error on the best-case values. So you need to define the actual tube and its operating point before refinement can go further.
I don't know what is wrong with the "Magazine" plan.
Old 15th February 2020, 08:08 AM   #14
I am going to use the ecc83s in the first stage and ecc81 in the second stage. The magazine preamplifier and also the other one both uses the same tubes.
Old 15th February 2020, 12:34 PM   #15
Steve Morley is offline Steve Morley  Canada
If it were me I'd use ECC81 for both stages. I find modern ECC83s kind of flaky. As well, you will likely have the most noise from the first stage tube. Using all ECC81s will allow you to swap them around and put the quietest ones in the first stage. And, vintage ECC81s typically sell for way less vintage ECC83s. You won't be giving up much gain with the '81s.
Steve
Old 15th February 2020, 01:42 PM   #16
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
riaa amplifier
Originally Posted by ioannidis View Post
I know how use a simulator for the passive Riaa filter. I noticed that the circuit in the photo has about +1.7 dB at 100hz and -0.6 dB at 10khz compared to the other circuit. But I need to know the total response differences including input-output tube impedance etc. Thatís what I canít calculate.
Not sure what you call a simulator, bit if you really know how to use one all these impedances will become obvious.
In any case the series resistor is usually selected to be much larger than the tube stage output impedance, so that is seldom a factor.
Old 16th February 2020, 06:22 AM   #17
PRR's Avatar
Roughly true.
The OP is not satisfied with the apparent +/-2dB errors of his present plan (I agree, though I've used worse). So small differences matter.
We have a suggestion for ECC81/12AT7, which I happened to figure as 3k. I would expect +/-20% deviation around nominal, so +/-600r, total 1200r error. For 1dB error we want the fixed resistor 10X bigger, 12k. For 0.25dB error, 4X of that, 48k. So the 30k-70k values in this thread are in the right ballpark for this tube, pretty much.
Too much higher would require figuring thermal hiss, and beg for stray noise in the high impedance. Let's pencil 60k. But since the tube is 3k, the actual resistor is 57k. At this point you stop and find out what good resistors are in-stock for order.
Old 16th February 2020, 05:26 PM   #18
DATIR is offline DATIR
In 2018 i designed a pcb with 3 stages srpp, 2 stages for phono preamplifier and one for line stage, the schematic is from ANZAI, some friends built the preamp.
File Type: jpg 52104936_1068055716713949_8245830393589137408_n.jpg (89.6 KB, 124 views)
File Type: jpg 75062786_2784260458259306_3415410864826613760_n.jpg (101.3 KB, 122 views)
Old 16th February 2020, 05:53 PM   #19
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Why not take the 2 tubestage phonostage to the next level. See diagram below.
Less hiss and distorsion. With standard values in riaa filter.
Old 16th February 2020, 05:57 PM   #20
Ketje is offline Ketje  Belgium
Ketje's Avatar
R6-R19 = 62k , rather 6k2 !
And here the same mistake to put R11 after the filter.Gives a unwanted devider R1-R11. With R11 in front of the filter, before R1, one gets extra free gain. And R11 doesn't need to be that small, 470k will do easely.
The value of R1 changes, the filter sees R1+Rout(SRPP)//R11 but with R11 in front it's now R1 in series with R11//Rout(SRPP)=~Rout.
Mona
riaa amplifierHide this!Advertise here!
Solid State Phono Pre-Amplifier with RIAA LCR Network - Overview wanted tiefbassuebertr Analogue Source 2 17th February 2018 08:47 PM
What type of RIAA for Denon Dl103 cart to Gainclone LM3875 amplifier tralalalala Analogue Source 9 3rd January 2016 03:34 PM
DIY turnable amplifier aka RIAA - newbie questions! hansibull Analog Line Level 22 23rd May 2014 08:53 PM
Need help on RIAA Andersen Tubes / Valves 35 28th April 2013 06:25 PM
Riaa........... Chris Everything Else 15 12th September 2001 03:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
