Tube turned black and rainbow. Cause?
Old 16th February 2020, 05:37 PM   #51
kodabmx is offline kodabmx  Canada
Spreading triode love.
It's hard to tell by the picture, but I thought they were Bakelite.
PL08 Omron Automation and Safety | Relays | DigiKey
If you can't learn to do something well, learn how to enjoy doing it poorly.
Old 16th February 2020, 06:19 PM   #52
marknoir is offline marknoir  United States
Originally Posted by smoking-amp View Post
Those are -plastic- relay sockets!! They are not rated for the high temps tubes produce. And someone already mentioned that that position gets poor air circulation. You would do well to change all the sockets to ceramic ones. The plastic may be near semi-conducting by now.
I think you are correct. But surprisingly these sockets survive in Jadis amps for 20 ys
Old 16th February 2020, 07:05 PM   #53
Default Sockets
They are Bakelite. The relays they are designed to work with sometimes carry a lot of current.
Old 16th February 2020, 08:57 PM   #54
Then they are fine. I have Bakelite sockets that are still fine after 70 years in some equipment.
Old 16th February 2020, 10:49 PM   #55
TonyTecson is offline TonyTecson  Philippines
diyAudio Moderator Emeritus
TonyTecson's Avatar
i valued the "cinch" sockets, i get them used, but they are way better than modern ceramic stuffs from china, those ceramic sockets break the center guide pin on octals...
if people react to you a certain way, it is not because of them but more because of you....
Old Yesterday, 02:59 PM   #56
Hey Tony. Ever use these? 20pc 8pin Bakelite vacuum tube socket octal for Chassis EL34 KT88 6550 6SN7 amps | eBay
I use these when I build with octal. The ground tabs are very handy Never had any of them loosen up.
Old Yesterday, 11:29 PM   #57
TonyTecson's Avatar
i prefer to use those cinch sockets that were pulled out from surplus military gears.....very reliable, with ground tabs too...
Tube turned black and rainbow. Cause?Hide this!Advertise here!
JL Slash Amp 500/1 makes Popping Sound when Turned on and low rumble when turned Off richyim Car Audio 20 10th January 2020 05:09 PM
5687 tube-based preamp with Tung-Sol Black plates, Sylvana and Phillips ECG tube pair networld Swap Meet 3 10th August 2014 02:23 AM
Rainbow Trout OB GregOH1 Multi-Way 8 10th July 2010 02:52 PM
DIY tube amp squeals when turned up jjai Tubes / Valves 4 7th September 2005 02:32 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
