Suggestions for parafeed OPT - Any guidance out there?
Suggestions for parafeed OPT - Any guidance out there? Please consider donating to help us continue to serve you.
Old 15th February 2020, 01:28 PM   #21
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Accepted. Indeed I misused the LCr meter.
My apologies.
Thanks again.
Copacetic
Old 17th February 2020, 06:59 PM   #22
Now I have measured the impedance of the transformer I have been using I can confirm some facts...
Rather than quote an impedance ratio of 15k:300R, which isnt the full picture at all
Thanks to PRR for pointing out the obvious (test method that I cant believe I didn't think of myself), pointing out my obvious mistakes/assumptions.
Safe to say, yes I am foolish and spoke without thought.
The transformer in question has an impedance maximum of about 12k centred about 1kHz.
It's of fairly high Q, if that is the proper term to use. Impedance drops to less than 1k at each end of the BW.
I'd recently bought some small PC mount toroid to try with a similar advertised voltage ratio, but a 1.6VA in comparison to the 30VA I have been using.
Interestingly, these have a totally different impedance curve, and give a similar impedance maximum, and load well down 10Hz, with a turnover at somewhere between 500Hz and 1kHz..ending up about 1kOhm at 60kHz.
I'm not sure what I can glean from this...other than a transformer that has given me a reflected load of 12kOhm at 1kHz has worked well, at 1kHz
And the LNFB has done it's best to keep distortion in check, below and up until 1kHz at least.
Perhaps then I should aim for a better OPT around 12k:300, 25k:600, or the like?
Then hope the interwinding capacitance is low enough to keep impedance high, or move the peak higher in frequency?
Copacetic
Old 23rd February 2020, 05:14 PM   #23
Default And it goes something like this
Quite an interesting comparison between the original toroid, and the half of the smallest toroid I can find...
I wonder what use a second isolated primary winding would be?
A source for feedback?
A node to load with R or C perhaps, to tune the other windings?
Perhaps a source for Distributed Load connections- if I were using pentodes as pentodes.. ?
An answer (of sorts) always seems to generate more questions!
Copacetic
Suggestions for parafeed OPT - Any guidance out there?Hide this!Advertise here!
Need some guidance and suggestions for first DIY speaker project ExponentFlame11 Multi-Way 23 13th September 2017 12:02 PM
Tubes suggestions for parafeed headphones amp ? 00940 Tubes / Valves 16 27th August 2014 12:32 PM
807pp suggestions and guidance please aardvarkash10 Tubes / Valves 15 28th December 2008 01:32 PM
to parafeed or not to parafeed that is the question nhuwar Tubes / Valves 63 28th February 2007 01:29 PM
OTL or parafeed? Jaime Tubes / Valves 14 11th December 2005 08:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
