Gyrator impedance vs frequency
Gyrator impedance vs frequency Please consider donating to help us continue to serve you.
Old 16th January 2020, 12:37 AM   #21
hellokitty123 is offline hellokitty123  United States
An inductor will act as a high impedance to AC but a low impedance to DC, in other words if you slap an inductor onto the plate of a tube or something, the tube's bias will determine the current through the inductor.
Since an inductor doesn't set the idle curren't it doesn't set the idle plate voltage, unlike a current source where the plate voltage must be determined by the current set by the current source due to ohms law.
A gyrator as I'm assuming we're talking about, is an electronic inductor. It can't swing beyond the rails like an inductor, but it will present a high impedance to AC without affecting the idle current.
Old 16th January 2020, 03:13 AM   #22
Originally Posted by Elerion View Post
Really? Talking about the two circuits I posted: the mosfet set a crude but real voltage reference, then the two resistors attached to the gate, which make a voltage divider, can be used to vary the anode voltage. Am I wrong?
Sorry didn't see you're post.
You're mostfets are Pcan with a fixed voltage on the gate and the high impedance end facing the load so it will function as a current source, not a gyrator in that configuration.
If you want to make a gyrator with the same complexity of your circuits you want something like this
The current source ensures a stable voltage across the R3
The mosfet is a source follower so it sets the voltage and the capacitor allows AC feedback to create a high impedance at AC.
You can take the output at either side of R4 depending on how much you want to load the triode or whatever your connecting and whether or not you want the signal current to enter the power supply.
Taking it above the resistor keeps a constant current on the load and lets the mosfet drive the next stage. Taking it below the resistor removes the constant current from the load but ensures the signal current does not enter the power supply.
Bartola and Rod Coleman makes PCBs for this type of circuit that perform about as well as can be expected without throwing an opamp in there.
Old 16th January 2020, 09:02 AM   #23
Elerion is online now Elerion  Spain
Originally Posted by Hearinspace View Post
Not being knowledgeable enough to analyze the circuit I have to ask in what way it acts like an inductor. Rising impedance with frequency? Swing above supply voltage?
Not sure. That's precisely the reason why I started this post.
I surely doesn't swing above supply (no gyrator does, AFAIK).
They seem to have a rising impedance with frequency, and act as inductive reactance (current lags voltage), in a range of frequencies.
Old 16th January 2020, 09:15 AM   #24
Thank you. I knew those circuits too. In fact, Bartola website shows a PMOS gyrator like the simple one I posted, and Ale (author) even posted it in this forum as a gyrator. Attached. The other one I posted is based on Salas and Anatoly's (Wavebourn) design . They are people who seem to know what they are talking about. So, I'm jus trying to put all the pieces together and understand by myself.
Old 16th January 2020, 05:06 PM   #25
Oh haha, I guess I am blind afterall, yeah that's a gyrator, I totally was not paying attention to where the divider was feeding.
The resistor divider + capacitor combined with R4 allows for AC feedback from the output to ensure that the VGS voltage is the same at AC so the AC current doesn't change. Think of R4 as a resistor load for a source follower, it will try to keep the VGS voltage equal and an unchanging VGS on a mosfet means a constant current.
Feeding the divider to the output also allows the idle current to be set via the load instead of the gyrator because the load resistance is part of the divider.
But changing the divider should still cause the gyrator to change the idle current somewhat. Seems way too flimsy for my liking but it will work in a pinch.
Old 18th January 2020, 01:47 PM   #26
But that gets us back to the first post.
In #9 (Gyrator impedance vs frequency) the simulation shows that it only acts as an inductor at very low frequencies, where the impedance is reactive.
See the top (magenta) trace. The phase is just close to 90 (voltage leads current) for very low frequencies. Then, it acts as a simple fair CCS, ok for low internal impedance tubes.
The question I was trying to ask in this thread from the very beginning is: is this the way the circuit is supposed to work?
Old 18th January 2020, 09:57 PM   #27
As I've explained the intent of a gyrator for audio purposes is to act as a current source at AC and a voltage source at DC.
To my eyes the magenta circuit is functioning as expected, acting as a high impedance at audio frequencies.
The green circuit was missing the source resistor in the first few posts and it is not optional, the circuit won't function correctly without it for reasons I explained in my last post.
Old Yesterday, 08:00 PM   #28
That makes much more sense. Thank you!
Gyrator impedance vs frequencyHide this!Advertise here!
Wirewound Resistors: Impedance vs Frequency GerryCo Parts 27 14th June 2019 12:57 PM
Gyrator Frequency Response? SGregory Tubes / Valves 96 7th December 2010 05:25 AM
Help with reading frequency/impedance chart retroman Multi-Way 1 21st July 2009 08:06 AM
impedance and frequency response relation MisterTwister Multi-Way 3 16th July 2009 03:37 AM
Impedance v.s. frequency maylar Multi-Way 1 5th January 2005 02:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
