Help!!! Tubes4Hifi SP14 noisy
Help!!! Tubes4Hifi SP14 noisy Please consider donating to help us continue to serve you.
Old 3rd January 2020, 01:54 AM   #11
rayma is offline rayma  United States
Originally Posted by luvrockin View Post
I tried that earlier tonight with no benefit but I didn’t flip the plug over.
The only reason to ever use one is for testing by reversing the plug.
The safety grounds must always remain connected. Never float the chassis,
that can be deadly.
See page 40 here:
https://web.mit.edu/jhawk/tmp/p/EST0...ps_handout.pdf
Old 3rd January 2020, 09:26 AM   #12
petertub is offline petertub  Sweden
%snip%
If the preamp is connected to the amps by itself, (nothing plugged into it, no other source inputs) there is the noise issue.
Good observation!
Do you have noise with volume turned down ? Does it change by switching
input ? Does it change by changing volume ?
Will the noise change if you disconnect the protective ground ( cheater plug ) ?
And what is the noise anyway? Do you have access to a scope to show the noise ?
My home is at www.tubular-well.se
Old 3rd January 2020, 10:42 AM   #13
luvrockin is offline luvrockin
The volume control has no effect. This thing buzzes the same amount at zero as half way turned up. The input selector has NO effect. The same input 1-4. I tried the cheater plug for a minute. When I saw it made no difference, I removed it and plugged back in without it. I don’t know what kind of noise it is. I don’t have a scope. I suppose I could possibly look for a cheap used one and purchase it. But then I’d have to learn how to use it as well. That may be a stretch.
Old 3rd January 2020, 02:26 PM   #14
The volume control has no effect. This thing buzzes the same amount at zero as half way turned up. The input selector has NO effect. The same input 1-4. I tried the cheater plug for a minute. When I saw it made no difference, I removed it and plugged back in without it. I donít know what kind of noise it is. I donít have a scope. I suppose I could possibly look for a cheap used one and purchase it. But then Iíd have to learn how to use it as well. That may be a stretch.
Thanx.
It seems to be the B+ ( or at least the outermost stage) that generates noise.
At lest grounding issues are eliminated. It would be interesting to measure
internals. Do you got schematics with the unit ?
Old 3rd January 2020, 05:41 PM   #15
I believe I do. I will dig when I get home. I don’t remember what there were offhand but I do know that after I built it and when troubleshooting the noise problem confirmed the B+ voltage was in spec. I will check when I get home after work.
Old 14th January 2020, 09:10 PM   #16
IEales is offline IEales
The issue likely the same as I had with VTA built M-125s.
See teaching the VTA M-125 to sing
If you use a Y cord with a shorting plug or just plug 1 RCA cable into both amps, they will likely hum due to the fact that the M-125 has a 9 point ground tied to Earth Safety.
I quietened my M-125s by nearly 40db. I now have to look at the tubes to see if the amps are on.
Old 14th January 2020, 10:43 PM   #17
Default SHORTED RCA cable
OOPs. I meant SHORTED RCA cable above ^^^
Old 16th January 2020, 02:15 PM   #18
claudiomas is offline claudiomas  France
claudiomas's Avatar
Send a message via MSN to claudiomas
long time ago my customer built this kit
and there was hiss noise or something like this
parallel a X nF cap on input tube anode resistor
i send informations to Roy @ this time....
overbiased
http://claudiomas.monsite-orange.fr/
Help!!! Tubes4Hifi SP14 noisyHide this!Advertise here!
transcendence masterpiece vs. tubes4hifi SP14 Jeffreyjuice Analog Line Level 7 23rd May 2019 07:20 PM
FS: SP14 Preamp by Roy Mottran marybety Swap Meet 0 8th August 2017 12:38 AM
WTB: Tubes4hifi SP14 preamp hausera Swap Meet 1 28th July 2017 07:50 PM
SP14 dratto Tubes / Valves 1 21st November 2016 01:57 PM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 05:07 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
