Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#11 |
Yes that was at half power on the primary....120 volts. So all sorted out now! Thanks all.
#12 |
I also Built the KT88 Blueglow amplifier...
under no load the B+ is going to be off the charts... its not important till the amplifier is under load... using the 5AR4 rec tube the B+ across the main filter cap under load should be right around 460V DC.. you should avoid running the B+ with no load... it will be to high for the power supply cap.. 100-100 500V if you need any help just message me.. ALSO.. it s a awesome amplifier !. Dan.. |
Thread | Thread Starter | Forum | Replies | Last Post |
Custom wound high voltage high current OPTs, PTs and chokes needed | thomasweissbach | Tubes / Valves | 21 | 13th November 2018 11:15 AM |
FS: High voltage (5kv-10kv) high value metal film resistors (100Mohm - 680Mohm) | moomilk | Swap Meet | 4 | 11th January 2016 06:46 AM |
Cheap high voltage high wattage dual rail SMPS devices | minimelkav | Power Supplies | 2 | 22nd August 2014 04:35 PM |
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 09:05 PM |
New To Site? | Need Help? |
