PrimaLuna Prologue 5 Issue and schematic
PrimaLuna Prologue 5 Issue and schematic Please consider donating to help us continue to serve you.
Old 2nd December 2019, 08:41 PM   #21
petertub is offline petertub  Sweden
Originally Posted by vishalk View Post
Thanks to mravinsky for the schematic which the cayin ta-35 which is similar if not the same as the prologue 5
Attachment 799298
This seems to be a beginners amp, at a quick look i identified C5 and C6
who will have overvoltage at power-on. ( 407V at one side, -30V at the other
while spec at 400V)
Maybe this is a reason not to supply schematics
My home is at www.tubular-well.se
Old 2nd December 2019, 09:22 PM   #22
aboos is offline aboos  Germany
Do not change the capacitors - all these MKPs are ok. Nothing is burned or looks like damaged by heat.
The first thing I would check are the bias voltages of the output tubes and the bias voltage supply. As far as I understood, both channels are affected.Bias voltages can be checked as well as plate and G2 screen voltages of the output tubes. Depending on the installed output tubes you can look up in the valve datasheet if the measured voltages will make any sense.
Old 2nd December 2019, 09:30 PM   #23
Next step would be the supply voltage for the input tube(s). Left and right channel have one common supply of 200V regulated by a zener diode. A failure of the zener could bias the input tube and/or phase splitter completely on or off. When switching of the amp, voltages will go down and you get a somehow reasonable biasing of the input section even if the zener is open.
Old 2nd December 2019, 09:52 PM   #24
vishalk is offline vishalk  United Kingdom
vishalk's Avatar
Aboos this is great information and makes sense thank you for your input this gives me more confidence to source the problem and solve it.
Old 2nd December 2019, 11:05 PM   #25
Galu is offline Galu  Scotland
Aboos this is great information and makes sense.
Sure beats my mention of a plate fuse, but thanks to you and rayma for taking the trouble to recognise my contribution!
Old 2nd December 2019, 11:10 PM   #26
rayma is offline rayma  United States
There are often hidden fuses around, even inside transformers, and in speaker enclosures (thermal tweeter fuse/switch).
Old 15th December 2019, 01:34 PM   #27
vishalk's Avatar
OK guys the strangest thing happens, I played music through the amplifier and when I measure the voltages across the these capacitors (bias board) the sound returns to normal? If I do this for each one it works, but as soon as I disconnect the test leads the sound goes back to being low and crackly??
All the voltages seem to be OK, am I missing something. Why does the sound go back to normal when I measure across the these capacitors?
PrimaLuna Prologue 5 Issue and schematicHide this!Advertise here!
Searching for Primaluna Prologue Three schematic albamaiuscola Tubes / Valves 4 16th January 2020 07:28 PM
PrimaLuna Prologue Two Inductionist Tubes / Valves 7 16th October 2017 07:01 PM
PrimaLuna ProLogue Eight stop turning HELP!!! Sakharov Digital Source 0 23rd July 2016 12:49 AM
Please Help: CDP Primaluna P8 for repair farl Digital Source 3 12th September 2010 08:08 PM
Tweeters in the old pioneer prologue 7 hjelm Multi-Way 3 26th February 2004 02:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
