Problem using Hammond 126C IST
Old 31st March 2020, 02:23 PM   #141
euro21 is offline euro21  Hungary
5C3S "near" equivalent is 5U4G (not A or B).
Old 31st March 2020, 04:12 PM   #142
goddlediddles is offline goddlediddles  Ireland
goddlediddles's Avatar
Thanks for that. It's great information. It looks like the one to go for is the 5AU4. It has has the same pin-out, but the filament current is 4.5 Amps. I think I have enough grunt in the power transformer to supply an extra 1.5 Amps. The 5V winding has a DCR of only .062Ω, so there should not be any great voltage drop with 4.5A. They are readily available on the web for about $20. No harm in getting one to try it out.
Old 31st March 2020, 06:02 PM   #143
I retired this tube (5C4S) long ago.
Instead of it I use 5U4GB (NOS black plate Tung-Sol) in my 300B SE.
Old 2nd April 2020, 05:54 PM   #144
I'm not sure, that this is the most decent driver for 300B.
Single stage 6SN7 has no enough gain -even with CCS load-, thus at higher input level this stage is the limiting factor.
Here is the asc file:
Old 2nd April 2020, 06:09 PM   #145
Great, many thanks again.
Old 3rd April 2020, 01:56 PM   #146
Originally Posted by 6A3sUMMER View Post
At 130 posts, we are in danger of a moving target (which can never be hit). We could go on forever, but lets settle on a design.
Yes, but I'm learning new stuff all the time. In the end we might end up with the best simple 300B SET design of all time. I'm grateful to you for introducing me to the IXCP10M90S, and to euro21 for getting me hooked on LTSpice. I'm learning it very slowly because it's a steep learning curve. Administrator Mooly has done a fine tutorial as a sticky, and is very good at answering all my silly questions. BTW, euro21's simulation of the paralleled 6SN7s is just what I needed. 1.2% distortion at 70 Volts peak drive is very impressive. Soon I will be able to do my own simulations on LTSpice if I can locate some models for the 6SN7.
Old 5th April 2020, 08:41 AM   #147
And one more request: could you share the 6SN7 model that you used? Many thanks again.
Old 5th April 2020, 01:57 PM   #148
Download Stephie (formerly Steve) Bench tube libraries:
:: View Forum - Circuits
Old 5th April 2020, 01:59 PM   #149
I'll do that now, thanks.
Problem using Hammond 126C ISTHide this!Advertise here!
FS: Hammond 159ZJ 10mH 5A chokes and Hammond Choke 158T DIYspaceW Swap Meet 3 18th September 2019 07:58 PM
FS: Hammond 1650R & Hammond 278CX freddi Swap Meet 0 4th February 2018 07:20 AM
Hammond L-112 30ips Tubes / Valves 2 17th January 2013 08:38 PM
-126C Cryogenic Treatment Hi-End Schuke AC Plug A&B-SYSTEMS Vendor's Bazaar 0 20th February 2012 07:14 PM
Those using a Hammond 374-BX... amandarae Tubelab 8 13th April 2011 01:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
