How does a tube's need for bias change with age?
Old 20th November 2019, 03:57 AM   #11
kodabmx is offline kodabmx  Canada
Spreading triode love.
Originally Posted by charnich74 View Post
I'm not exactly sure how to phrase this with the proper terminology, but I was wondering if a tube's need for bias changes in a consistent direction with the age of the tube. In other words is there a common trend universal to all tubes? For example if you check bias after one year of use is there a trend to need to correct bias by increasing negative bias voltage, or decrease it? Or does it vary depending on tube type? If you were to set bias on the hot side to begin with would it tend to cool over time? Again apologies if the terminology is wrong or if this is a moronically basic question.
Cheers
I say it all depends on the circuit the tube is being used in. Cathode bias tries to adjust for tube wear and differences in tubes, whereas fixed bias does not.
If you run a tube hard/hot, you'll wear it out faster. In theory, a tube running at like 25% of it's total Pd will last as long as the heater. Some people require perfectly matched tube from a cryogenic treatment plant, others prefer buying a bunch of cheap unpopular tubes and matching them. FWIW I find old US sweep tubes like my 36LW6 take about an hour to "settle" every time I turn the amp on. It has a meter for each tube so I can see the biasing in real time. After about an hour, maybe a little less, when the amp is running at temperature, the bias falls perfectly inline to how it was set but there might be a mismatch of like 40mA within the first minute of power... The tubes are biased at 120mA each though, so the mismatch is "only" 16%. Still, if the design is good, most people wouldn't notice the mismatch as long as they keep it within the class A power envelope. My Soviet 6P45S tubes take far less time, and the 6P43P comes up to bias and stays there in 11 seconds, even never used old stock.
Generally, if it's fixed bias, you should check it "once in a while", unless you have a reason to check it like it starts to sound like rubbish. Bonus points for cleaning and using the biasing pots to keep them in good condition. Nothing more annoying than trying to rebias an old and and breaking the damned pot
OTOH, there are automatic biasing boards available for a more "set it and forget it" approach. I use several and I'm generally pleased with them.
Old 20th November 2019, 07:26 AM   #12
6vheater is offline 6vheater
Send a message via ICQ to 6vheater How does a tube's need for bias change with age?
yes except in class B, like you are suggesting audio valves sound terrible.
Class A cathode biased amps make loads of extra distortion, get unstable with certain loads and don't deliver the power, again partly because of screen voltage effective variations.
Ultralinear is also a non starter with cathode bias because the critical screen load is constantly varying.
plus the "cryogenic" nonsense is yet another example of pseudo science.
Why?
Because, if it could be proved to have been useful, the major industrial valve manufacturers like GEC would have done it Eons ago, especially for their monster FM broadcast transmitting stuff.
They had most to gain from it.
my personal opinion:-
Yet another example of junk science being applied, on top of which you can have very little idea of what is really going on in terms of vac inside the component.
Sure as anything I wouldn't expose glass & brittle bakelite bases to extremes of temperature provoking shrinkage/expansion of all the solder joints... I have enough trouble with dry joints in valve bases as it is!
As for running the valves close to limit Pa, you literally don't have any choice there.
The point of least distortion/best sound on 6V6/6L6 and most US beam tetrodes has always been regarded as being just close to the point where it's about to melt, to the point we often wonder how those 6V6 hang in there at all in Guitar amps.
The 7591 is no different, because as I said before it's basically half a 8417,- half the gain, half the anode power, and voltage limited to 450V.
People like Scott, Sherwood et al, knew all this stuff, which is why they run them so hot.
Their previous version of Sherwoods/Scotts used EL84, which is a pentode, but they were short on power so they hammered them to death.
I reckon they were incredibly relieved when Westinghouse-Sylvania and RCA came up with the 7591.
As for biasing:-
(proof for over-driving,- the little known technique to run the 807 - 6L6oid, at as high an anode voltage and Pa as you dare)...
It's one of those undocumented areas, running the 807 around 400V, 300V screen makes a lot of quite nasty sounding 3rd/5th harmonic distortion.
Banging the anode volts up to more like 600, 650, or even 700-800V miraculously gives it an amazingly good sound, where the harmonics start to disappear.
That's because the transconductance curves straighten up.
So, if you want good sound and no cross over distortion you HAVE to run push-pull amps at at least 70% of max idle diss. No choice.
TBH, I find they usually sound even better, even optimal at close to 85%, which makes duff or sub par valves start to glow around hot spots in the anodes.
Old 20th November 2019, 08:15 AM   #13
Jazid is offline Jazid  United Kingdom
Originally Posted by 6vheater View Post
I have another 200 more of the finest to select out over new year.
These were made in 1973, - the best possible imagineable quality GEC-Marconi.
I don't see anything like the phenomenon you describe.
Being as I am fitting them as matched quads, you can begin to imagine I don't have huge patience with the argument that what I might be doing would be pointless or stupid.
Fact is running them at proper voltages and loads, 45yrs later they behave much as you would expect.
Para 1. You are using late stock mil-spec valves with flying leads - 'best possible imaginable quality' . I am coaxing often 80+ year old valves out of their slumber. That is my choice and I report what I find. I imagine you choose the valves you do to avoid such issues, and fair enough. But your findings are conditioned by your choices, mine by mine, our parameters are different and there is no contention except in your mind.
Para 2. No one is accusing you of this, what are you so defensive about? Perhaps try to stick to the point?
Para 3. This is indeed true but does not fit with anything you mention in later posts where you advocate driving output valves extremely hard for distortion and sound quality. Manufacturers service life spec applies to valves driven hard, and it rarely exceeds 10000 hours, for output tubes much less, as you well know.
Edit: Tapatalk has displayed paragraphs weirdly, now para's 1, 2,3 are all referred to as para 1 above...
Old 20th November 2019, 08:27 AM   #14
disco is offline disco  Netherlands
disco's Avatar
When you start up one of these new stock valves you see a burst of emission to begin with, then they slowly settle. I reckon at worst it takes 5 mins,- after this point it's just not going to move any more.
The whole ****-eyed story that "burning in takes weeks" and the sound alters is entirely imaginary...(as I can clearly see on a meter) but there, you have to humour people who believe in fairy stories...
What I read here and there is the observation a new amplifier gives its best the first hour, to decline furtheron and come back to optimal reproduction within weeks or even months. That effect would come down to settling components which depend on chemical reaction or mechanical construction. In case of old electrolytes I can imagine a change in the oxide coating forming and perhaps with tubes a change in the surface layer of the heater.
Emission of new tubes is understood to be a function of the distance between heater and grid, being not constant with production (less so with frame grid tubes). Perhaps the sag of the coated wolfram wire plays a role with used tubes, but certainly the heater ability to boil off electrons gets exhausted over time.
jaap
Old 20th November 2019, 08:48 AM   #15
I'm using 60-70 yr old 807s in one of the amps I run (direct coupled AB2).
They are as fresh as the day they were made.
The circuit drives the input up to 20V positive, which means even g1 is conducting a decent bit of current, easy over 10m/a.
On the really big ones I have (125W with 830V HT), they doubled up the driver valves to drive them even harder.
The thing that died on them?
The HT transformers!
Hammering the living daylights out of them doesn't seem to make any difference at all, and I have no idea what they were used for previously, they are all unknown s/h stuff from a batch of 25+.
I culled some, some broke off top caps, and just a few were sub par.
Radio hams used to use them all the time, and caned them for hours at anything up to 50mhz.
I am always suprised by the 807, with it's weeny 0.9A heater, but that and the 0.45A 6V6 were state of the art and had to be carried into battlefields or stuck in bombers.
In the other pair of similar hifi amps, I'm also using 70yr old KT8s.
They have much larger cathodes, stronger heaters, and TBH, I somehow imagine they will get to 100yrs old, still going ridiculously well.
You can drive them to 75W with a square wave and they just glow a bit.
Consumer stuff just melts and blows up.
Fact is, if you use marginal comsumer grade valves you get consumer grade life.
Horses for courses and all that.
It suited the valve makers to get good stock turnover, because replacement valves were very expensive, - exactly the same rule as autoparts.
Look at it New Sensor are dead happy people blowing up 6L6GC with their guitars, it just sells more parts!
In the mil with JAN stuff, they just popped down the stores and pulled out another 30 of them.
Another century, another story.
The US manufacturers stuck their mil grade stuff on steroids when they started making colour TVs.
Fact is the cathodes are so advanced and so enormous on some of them, they will conduct one AMP at 700V.
They even quote an "overload factor" for so many uS without affecting life.
Old 20th November 2019, 02:21 PM   #16
I find you either need to bias them hot as you describe, or as low as you can while getting rid of the notch. This also helps with GM doubling apparently. Also like 99% of listening is in the first watt. As long as it's biased hot enough to give 1W class A, it's usually good, although I admittedly have mine set up for closer to 15W class A limit (112W total RMS power)...
Old 20th November 2019, 02:41 PM   #17
Also like 99% of listening is in the first watt. As long as it's biased hot enough to give 1W class A, ... mine set up for closer to 15W class A limit (112W total RMS power)...
I think this first watt is another one of these popular myths and legends.
Fact is, nearly all energy is concentrated in the first 100hz.
(You can FFT the result and it gives the game away)
When you start to look closely, most speakers work very badly in this area, and of course the ear being very insensitive to distortion down there, and at least 10-15dB down in response, makes a nonsense of this 1W rule.
Another thing.
The anode dissipation problem.
Class A area spread wider and wider, the more Pa you have available.
I use typically valves which have 18-19W diss for smaller amps (from small PPP quads), and 35-40W for larger amps with just pairs.
(in my case the small pairs used in matched quads have a stupidly MASSIVE heater and cathode.. 0.635A for a valve the size of your finger, and a brief check, dropping bias momentarily to zero....conducts more than 1/4 of an amp at 500V).
That's the great part about industrial voltage stabiliser valves, rather than consumer grade stuff.
If you work it out, that's effectively a composite 18W valve - conservative book figure -with a 1.3A heater....almost the power of a KT66 in a size no bigger than a large felt tip marker!
There's a smart reason for using PPP, especially with small valves.
It's got a lot to do with increasing transconductance & advantages in the low powered output end.
It also tends to hide aging away quite well, although I find you have to be much more careful with oscillation.
If you look at the width of that "class A" operating area, it's clear the larger amps, sitting with a pair of valves at 27-30W idle are going to be able to deliver a lot more linear class A power than something smaller....as much as 22-25W in fact, before moving into the class AB area.
I saw just a few people using 6V6 in PPP.
They are quite suprising run that way.
The miniature versions like 6BW6 take up no space and have low heater requirements.
If you listen to lots of Organ music, try running in that 'first watt".
It doesn't work!
Old 20th November 2019, 02:56 PM   #18
The fact is, my speakers are 95db 1W-1m... This is excessive SPL for most purposes. This is what I mean by the first watt of power. Also, the logarithmic response of the ear means you need 10 times the power to realize 2 times the "volume".
Anode dissipation is just a number. As long as the cathode can provide the current, the glass is kept within specs (cooler the glass, the longer the tube life, apparently), and the plates don't incandesce (red plate), you're good. That's why I can run 36LW6 tubes at 35W Pd...
This is an interesting book: http://www.tubebooks.org/Books/Atwoo...um%20Tubes.pdf
I've build PPPP 6P1P (Stupendous amplifier on here), and my monoblocs are PPP 6P45S @ 35W each. I rarely ever use anything other than Triode connection, so oscillation rarely is an issue, and if it is, a 10R-27R power resistor on the plate of each tube solves it.
If you can't enjoy organ music in the first watt, you're speakers aren't sensitive enough IMHO. FWIW, with my Energy RC70s and my monoblocs, I can max the scale on my SPL meter, however, apparently the "Sound meter do not follow a A or C curve and readings will be too low at 1000Hz and above" It's designed for measuring HVAC noise.
Old 20th November 2019, 03:56 PM   #19
Mark Tillotson is online now Mark Tillotson
Actually anodes can incandesce no problem in high power tubes - normally nickel alloys are used for such anodes and they keep mechanically strong at red and orange heat. In small tubes the glass is too close to the anodes to allow red-plating without damage.
The physics of electron tubes means the bias ought to be fairly stable, as the voltage ratios between electrodes should be principally a function of the geometry of the electrodes. However the actual current does depend on the electron cloud density (aka space charge), which is affected by emissivity and thus temperature of the cathode.
As I understand it most receiving tubes (that's anything except high power RF transmitting tubes really) are always designed to have lots of emission to spare so that as the cathode degrades it makes less difference to performance or bias point.
Old 20th November 2019, 04:28 PM   #20
Originally Posted by Mark Tillotson View Post
Actually anodes can incandesce no problem in high power tubes - normally nickel alloys are used for such anodes* and they keep mechanically strong at red and orange heat.
Hence why 807s can be caned to death.*
They don't have the same structures, metals nor the smaller size of the smaller 6L6, never mind the Russki 6P3S-E or the 7591.
People forget also, industrial valves,- especially transmitter variants have special silica glass qualities that have no worries at all running at 250C.
(I think the STC 5B254M has this).
It's about half the size of EL34, but will eat one for breakfast in the longevity stakes.
I have industrial valves that will char cardboard, but they don't red plate, and they are tough as old boots.
The only way I could kill them was overdoing a square wave test at full chat, which melted the screens....so, well, now I know.
After that I knew they were damaged because the internals had distorted enough to make a section of the anode glow, where it didn't before.
The fact is, my speakers are 95db 1W-1m**... This is excessive SPL for most purposes.
If you can't enjoy organ music in the first watt, you're speakers aren't sensitive enough ... and my monoblocs, I can max the scale on my SPL meter, however...
This I doubt very much, but you can dream.
Nobody I know would try to reproduce a 25HZ organ note at 1m, it's impossible.
The wavelength is many 10s of feet long, so that's nonsense.
If you think you can get 95dB at 1W, down there, then that is purely imaginary at the low frequencies I am talking about.
Oh yes 400hz-1khz maybe, but not at 22-35hz.
For that, even with really CLASSY speakers you need serious power.
How does a tube's need for bias change with age?Hide this!Advertise here!
Amp Bias help ? Rebuild & Tube Change ! Gary Vee Instruments and Amps 2 11th February 2014 04:04 AM
How can I change bias 6H30pi tube wrangler Tubes / Valves 8 23rd August 2006 08:15 PM
Can I change Bias? mikee55 Solid State 25 15th February 2006 05:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
