coupling caps
coupling caps
coupling caps Please consider donating to help us continue to serve you.
Old 15th November 2019, 11:26 PM   #11
rayma is online now rayma  United States
Originally Posted by charnich74 View Post
TY for the tip on temps!
Don't let them (or any other caps) touch the tubes or anything else hot, though. Plastic film will melt.
Old 15th November 2019, 11:27 PM   #12
Tjj226 is offline Tjj226
Originally Posted by asuslover View Post
what series did you use?
716p I think.
Old 15th November 2019, 11:54 PM   #13
Diyengineer is offline Diyengineer  United States
I've bought other stuff them before but never even though of them for caps.
Yes, they have hundreds to choose from. I have used several Multicap brand caps for coupling caps from them and they seem to work well and are cheap.
Old 16th November 2019, 07:08 AM   #14
Chris Hornbeck is online now Chris Hornbeck  United States
Chris Hornbeck's Avatar
Another viewpoint on coupling capacitors, which I attribute to DF96: if there's no voltage across it, what effect can it have? Makes sense to me.
However, just to appease the wrathful Goddess of Audio, I use the affordable and reliable (never heard of a failure of any kind, ever) and ordinary, type 716P. Also contains Lanolin (Flanders and Swann reference for the children in the audience.)
All good fortune,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 16th November 2019, 12:33 PM   #15
pblix is offline pblix  United States
pblix's Avatar
I've never been able to "heard" a capacitor. They're awfully quiet in my house.
I only do new construction and I use Panasonic most of the time. Currently I use the ECWFE series in most of my amps. Cost effective and gets the job done. As always, YMMV.
Old 16th November 2019, 02:03 PM   #16
kodabmx is offline kodabmx  Canada
Spreading triode love.
coupling caps
I use these: MKP1839410634HQ Vishay BC Components | Capacitors | DigiKey
A cheaper option but radial instead of axial: F862BK104K310ALR0L KEMET | Capacitors | DigiKey
Old 17th November 2019, 04:32 PM   #17
tgreese is offline tgreese  United States
tgreese's Avatar
No love for the Wima polypropylene film/foil? They seem to be popular with the high-end consumer gear builders. FKP4J031005G00KYSD WIMA | Mouser
Old 17th November 2019, 08:07 PM   #18
coupling caps
They are good, but I build point to point so I don't use them.
Old 17th November 2019, 08:36 PM   #19
invaderzim is offline invaderzim  United States
invaderzim's Avatar
That was my thought; I've heard good things about them but for point to point longer leads are nice.
Old 17th November 2019, 09:03 PM   #20
coupling caps
Yup, especially the axial ones. Too bad they are more money. Most of the time I use Carli or Tenta X2 safety caps for coupling. They are like 20 cents a piece and they work very well.
MKP Safety Capacitor X2 275V 0.1uF/100nF/104K/0.22/0.47uf/220nf/330nf/224K/474K | eBay
coupling capsHide this!Advertise here!
Little dot MK2 coupling caps Datun Walnut Parts 4 16th October 2019 03:36 PM
Filter caps vs Coupling caps rpb123 Parts 2 19th December 2015 03:28 PM
Coupling Caps mr2racer Parts 23 4th March 2015 05:09 PM
coupling caps el capitan83 Parts 10 17th December 2004 05:25 PM
What value for the coupling caps? roibm Parts 12 23rd March 2004 06:58 PM
Copyright ©1999-2019 diyAudio
