Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#41 |
ok, so far I got six layers of paint on. What was I thinking spray painting in this cold weather. Sometimes thinking hurts but no gain without a little pain. It proved not a good idea to warm the chassis in a oven just before spray painting it outside
jaap |
#42 |
Been there before.... sanding bad finish, repaint only to get a drip or orange peeling. More sanding till your arm drops off : )
I've been painting a chassis this week, 2mm thick ali, I warm the various parts in front of the fire, not too warm though and put my spray can in the same place to warm giving it a shake every 5 minutes or so. Andy. |
#43 |
Spreading triode love.
I took 3 days to repaint a bicycle. I spent more time and money on stripper, paint, and sandpaper than it would have cost to have the thing powder coated.
#44 |
hey, it's the satisfaction of own labor that counts
jaap |
#45 |
Waitin' for the paint to stop dripping I did some more modelling, with Micro Cap this time. Output impedance is confirmed to be non-existant (flat from DC to 20KHz). Although the LTspice result is confirmed both programs might use the same dodgy underlaying core-SW. Opinions are welcome because I have a hard time to accept the not of this world outcome.
jaap |
Thread | Thread Starter | Forum | Replies | Last Post |
6SN7 Mu follower or cathode follower? | rhythmsandy | Tubes / Valves | 136 | 5th December 2019 06:56 PM |
Source follower VS white cathode follower | hellokitty123 | Tubes / Valves | 12 | 28th April 2018 12:16 AM |
CCS instead of a resistor in the cathode of a cathode follower? | Nailbunny7 | Tubes / Valves | 38 | 19th April 2016 08:58 AM |
Cathode follower PA Driver in a cathode biased amp | stephenl5 | Tubes / Valves | 6 | 19th April 2015 03:27 PM |
Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 07:47 PM |
New To Site? | Need Help? |
