Hum / oscillactions in EL84 push-pull amp
Old 11th November 2019, 09:04 AM   #21
Chris Hornbeck is online now Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by parilex View Post
Since both channels are equally affected, something like this seems most plausible to me. I'm pretty sure it's not external interference, as the measurements at another location were exactly the same. The amplitude of the oscillations is indeed very small and does not influence the sound reproduction noticeably. I am simply tempted to find or explain the cause of such problems/phenomena.
This is a worthy goal, and if I have inadvertently expressed myself poorly please forgive and accept an alternative description:
By "external", I only meant external to the intentional signal path. Noise sources in the power supplies are a possible example. You've ruled out distant noise sources, so your task is easily manageable. You see these pulses at twice AC line frequency? That's a good clue. What can you safely see with that software scope?
It looks like it might be a powerful tool to look at this issue, but you need to maintain a safety protocol looking into high Voltage power supplies.
All good fortune,
Chris
"A marveilous newtrality have these things mathematicall and also a strange participation between things supernaturall, immortall, intellectuall, simple and indivisible, and things naturall, mortall, sensible, componded and divisible." - John Dee
Old 11th November 2019, 09:10 AM   #22
I am on duty for the next few days
And that's another thing. Nobody tries to invade Switzerland because you guys are badass and you know where the bodies are buried. Respect.
Old 12th November 2019, 08:12 AM   #23
disco is offline disco  Netherlands
disco's Avatar
Ever smelled the cheese they make overthere? Makes a Vulcan cry.
jaap
Old 12th November 2019, 07:06 PM   #24
They even have tactical cheese. Badass.
Hum / oscillactions in EL84 push-pull ampHide this!Advertise here!
Hum with EL84 Push-Pull Kashmire Tubes / Valves 10 30th December 2009 01:15 AM
EL84 push pull slideman82 Tubes / Valves 4 19th June 2009 04:40 PM
Will this work for an EL84 push pull? zobsky Tubes / Valves 5 10th October 2006 08:42 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
EL84 Push Pull amp. hacknet Tubes / Valves 8 23rd September 2004 06:53 AM
Copyright ©1999-2019 diyAudio
