Ampex Plug-In Mic Pre 96440-02 Schematic and Pics
Old 2nd November 2019, 05:01 PM   #1
jlaber is offline jlaber  United States
Default Ampex Plug-In Mic Pre 96440-02 Schematic and Pics
Schematic and photos of an Ampex 96440-02 Microphone Preamplifier plugin unit are posted here:
Ampex Mic Pre Plugin 96440-02 | Flickr
This preamp uses an unmarked Beyer Dynamic input transformer and RCA Nuvistor tubes, housed in an octal-based aluminum can enclosure. It looks similar to the 96440-04 preamp for the Ampex 354, but it uses different tubes and is not listed as an option on the Ampex literature I found for the 354.
DC voltage supply resistor/capacitor comes from the 354 schematic, assuming this model preamp is compatible.
Old 3rd November 2019, 07:09 PM   #2
indianajo is offline indianajo  United States
indianajo's Avatar
Well, ****. flickr won't let me download this and there is no diyaudio image.
I have a collection of 7895 nuvistor tubes in boxes from some ancient trash bin. Now if I could find a socket that would connect to them . . .
I wonder if these were the style tubes that were in the air-burst artillery shells and prox anti-aircraft rounds at the end of WWII? A wartime secret never revealed.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 3rd November 2019, 07:47 PM   #3
PRR is offline PRR  United States
PRR's Avatar
Yes, Flikyer is a pain.
Consumer Nuvistors appeared in the late 1950s specifically for low-snow high-gain VHF reception for better fringe-area reception (and sales). Yes, they may have been based on military research. I've never seen that documented.
I've seen the same can but with transistors. I suspect it was originally a can for optional input transformers. Stuffing TO-18 was tight; stuffing tubes is amazing (and hot!).
Old 7th November 2019, 10:30 PM   #4
Sorry, I don't often have much time to post, and hadn't taken the time to look up how to attach files. They are attached here.
Old 8th November 2019, 09:44 AM   #5
petertub is online now petertub  Sweden
This was an impressively tight build !
Any opinions about it's quality as microphone amp ? Most if not all the parts are possible to source today..
My home is at www.tubular-well.se
Old 8th November 2019, 04:21 PM   #6
I haven't tried it yet. I don't have a deck to plug it into, so I reverse engineered it in order to rack it up with power supply, line amp and attenuators. I've been curious for decades about nuvistors in audio applications. Back in the day, the RCA TVs with nuvistor front ends said "New Vista Color" on them.
Ampex Plug-In Mic Pre 96440-02 Schematic and PicsHide this!Advertise here!
Push-Pull 6L6 or EL34 Schematic, Mullard 5-20 vs. Ampex 6516 force of 1/2 Tubes / Valves 35 23rd October 2019 11:22 PM
Radial phase plug vs concentric ring phase plug sean19 Multi-Way 17 7th April 2016 11:20 PM
Suggestion for plug-in enhancement or new plug-in Brisso57 miniDSP 1 8th November 2010 06:59 AM
chip burn-out when plug-in or plug-out DVD signal lines xujing79 Class D 3 3rd August 2010 06:07 AM
Ampex 354 reel to reel and Ampex MX-35 mixer for sale on ebay megaladonman Swap Meet 2 13th February 2005 10:01 PM
Copyright ©1999-2019 diyAudio
