Best way to reduce gain in this circuit?
Old 3rd November 2019, 12:56 AM   #41
kodabmx is offline kodabmx  Canada
Spreading triode love.
Nice. When I need to swing that kind of voltage, I use a 6F12P, and when I need more than that I add a 6SN7 My monoblocs' power stage needs 200Vpp for full output 2V RMS will drive it there I believe.
Old 3rd November 2019, 01:01 AM   #42
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Dunno if anyone's said it so far, but the “right answer” from an electrical/electronic engineering point of view is “attenuate the output”.
In your original postings, you mused that the 10 gain was too much, and 5 would have been better. As you can imagine, there is nothing in the world simpler than a 2-equal-resistors voltage divider. Nothing.
The reason why it is sound engineering is because (we learned early that) the contribution of noise in an overall circuit is most critical at the first gain stage. Whatever noise it introduces continues on thru the rest of the circuit. However … if its gain is reduced 50% by a 50:50 voltage divider … so is the output noise.
Just Saying,
GoatGuy ✓
Burnished unicorn horn circuit design only goes so far. When the magic disappoints, its best to rely on solid maths. Just Saying
Old 3rd November 2019, 12:27 PM   #43
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
My point exactly (post #32).
Old 21st November 2019, 12:32 AM   #44
Originally Posted by Ketje View Post
Before you make a nice oscillator with Jon's proposal , try it this way.
Mona
Thank you, Mona!
I ask though, why 100k/1M instead of say 3k3/33k? I figured the lower the resistors within reason, the less noise they would add?
Old 21st November 2019, 12:37 AM   #45
rayma is offline rayma  United States
As long as the source can drive them, and with no early bass roll off, the smaller the better.
The 3.3k/33k attenuator would require a 2.2 uF output capacitor in the source.
Old 21st November 2019, 10:43 AM   #46
Ketje is offline Ketje  Belgium
Ketje's Avatar
That's right.But the input impedance goes down too.
With the 3k3/33k proposal the input sees an impedance of 33/12+3,3=6k (gain without FB =~12x).
So "within reason" indeed.
Mona
Old 21st November 2019, 02:30 PM   #47
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
This thread is kinda painful to watch, so I'm gonna jump in with the folding chair:
Worrying about noise in this circuit is kinda redundant since it's not a low-noise circuit in the first place. Just eyeballing it, the equivalent input noise resistance of this circuit is going to be at least 15k, and that's ignoring any power supply hum (the half-mu stage only has 6dB PSRR, remember). You can easily put a 100k volume pot at the input with only a minor noise penalty. It's also a reasonable input impedance for a tube circuit. Doing this brings a headroom advantage and will make the circuit more 'useful' since the output follower will actually be driving the load with it's low output impedance.
If you still have too much gain then you can add a cathode bypass capacitor to the upper input triode. However, this will also change the distortion in a non-predictable way. See my book for more on this.
Buy my tube hi-fi book! www.valvewizard.co.uk
Old 21st November 2019, 04:27 PM   #48
Thanks, Merlin. Perhaps I have unrealistic expectations. Effectively, with this circuit, or another built from scratch, I'm trying to have a silent output at full volume. There is no hum already, just waterfall. It's not very loud, but I know my old solid state preamp will do it. You would think the system was turned off until you blow your ears off when you start the music (if you forgot it was full blast). My power amps have virtually no noise, ear to the speaker so I know the noise is coming either from the source, or the preamp.
Yesterday, I was experimenting with making an anode follower from a 6J1 strapped as a triode... It worked quite well. I even got a 10Hz square wave to stay level, and 10kHz square looks excellent, too.
Best way to reduce gain in this circuit?Hide this!Advertise here!
How to reduce a DAC gain LoneL Digital Line Level 3 24th May 2017 07:27 AM
What's the Best Way to Reduce Gain in a Preamp rcollege Tubes / Valves 14 23rd April 2014 08:25 PM
Aleph_Ono reduce gain ? nar Pass Labs 11 17th November 2011 09:07 AM
How to reduce the gain of the symasym 5_3? formula 22 Solid State 0 20th September 2011 05:13 PM
How to reduce gain in mu-follower? karsten21 Tubes / Valves 9 30th June 2011 11:31 PM
Copyright ©1999-2019 diyAudio
