Shall I use a tube plate voltage delay?
Old 22nd October 2019, 03:09 PM   #11
cyto is offline cyto  United States
cyto's Avatar
Originally Posted by wiseoldtech View Post
For decades, manufacturers made quality equipment.
These well-designed pieces lasted through the decades, so did their tubes.
And none of this equipment used any B+ delay stuff, the "delay" stuff started,.. ahem, once the internet came around,... and people with tube paranoia and obsessions warned others "of the dangers" ......oh my!..... "news travels!... believe it!"
Chalk this up to tubes becoming more scarce, prices going up (inflation/greed) and of course our lovely internet blabbering.
Tubes usually have a long lifespan, despite what some people believe.
When you've serviced as many 1930's-1950's radios and console stereos as I have, with originally installed tubes which tested fine, perhaps you'll understand things more clearly.
I went to electronics school in the 70s and worked as a tech after for a while. I wondered about the B+ delay everyone said was needed for tube circuits. I don't remember seeing it when I did it for a living. I got out of electronics and got into the medical field after a couple of years.
I figured I was just behind on the technology and B+ delay was needed, it seems my memory is correct, maybe?
Old 22nd October 2019, 03:16 PM   #12
JoeAlders is offline JoeAlders  Netherlands
I got my electronics education in the early and mid 60's of the last century. Tube theory( also semiconductor theory) was given intensively then.
I also cannot recall that plate voltage delay was mentioned at that time. Did a quick search into my books which we were using then and could not find anything about this topic.
Old 22nd October 2019, 04:38 PM   #13
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
Musical instrument amplifiers have used a switch called "standby" which kept the filament supply ON for a faster startup.
I never really understood the reasoning for it, since tubes usually "heat up" and produce "sound" in about a mere 15 seconds. - what's the rush?
Some mid-1960's television sets using tubes also had a "quick-start" feature to speed up picture and sound once the set is turned on. (and larger electric bills)
Basically a selling feature, perhaps geared towards impatient people, as was transistor radios. ("cool running, longer life, instant sound")
These "features" are simple marketing babble created to help sell products.
And of course, this "marketing babble" has naturally migrated to the internet and its hoardes of paranoid worrying souls.
Bohemian Guru Professional
Old 22nd October 2019, 05:15 PM   #14
Bigun is offline Bigun  Canada
Bigun's Avatar
I think a large part of the worrying started with a shift away from hollow state rectifiers and the use of solid-state diode rectifiers with their instant on performance. This topic has been debated on this forum several times in the past and the collected wisdom to my mind is that there is nothing that we tend to build on this forum that requires a turn on delay unless the particular circuit has design elements which produce unnecessary stress during start up. if I were to require a delay I would not only consider the excellent finished-product from Jan but also take a look to a DIY option, the circuit posted by member “wavebourne” which ramps the B+ up in proportion to the current being drawn - in other words it carefully pays out the rope as the tube pulls on it.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd October 2019, 07:56 PM   #15
That would be still interesting. Can you give the thread link please? Thanks in advance.
Old 23rd October 2019, 12:25 AM   #16
Bigun's Avatar
I don’t remember wavebourn having a dedicated thread, it’s a circuit he used in his commercial projects but he did publish it on the forum and I have attached the schematic and a link to at least one of his posts:
Simple B+ delay circuit for tube power amp?
File Type: jpeg D97BD92B-D36E-44C3-9770-15A7EE0BD308.jpeg (40.2 KB, 149 views)
Old 23rd October 2019, 12:46 AM   #17
trobbins is offline trobbins  Australia
trobbins's Avatar
A diy option for slow start with ss diode B+ rectifier is presented in section 5.5 on sequencing options in link:
https://dalmura.com.au/static/Power%...ube%20amps.pdf
It uses a cheap $2 adjustable time delay relay module from eBay to provide the timing and relay contact, and two modules can be set up to provide the initial delay prior to output stage loading the power supply, and then a slowed rise B+ phase using a NTC, which is then switched out of circuit. That could be a benefit if it allowed a lower rated fuse for mains AC or secondary side protection, or the initial B+ surge voltage could stress filter and bypass capacitors (eg. if mains AC sometimes goes high).
Old 23rd October 2019, 01:59 AM   #18
All this fussing around, the added complexity of fancy relays and delays - I guess some people are not happy or satisfied with simple, reliable, time-tested designs.
Worrying about capacitor stress and failures, tube life?, then build something properly in the first place.... paranoia sets in, and isn't pretty.
Because all this crap was never implimented before, nor was it needed.
My lovely OLD (and restored) 1963 RCA Victor console stereo with 18 tubes never needed delays and relays, and still doesn't.
And it survived the decades just fine.
Some of the original tubes (date stamped 1962) are still in it and still test good!
Old 23rd October 2019, 02:41 AM   #19
trobbins's Avatar
Not all vintage amps survive for decades, with many examples of replaced power and output transformers. Sure some of that equipment could have won Darwin awards, but there was also a huge kit industry with many thousands of amps made for 'hi-fi', and some models have shown less than stellar long term reliability.
Nowadays forum examples of sad newbs whose newly acquired valve amp has failed in short time with stories of emitted smoke, or damaged tubes or tweeters from tube rolling, or problems from various other actions like replacing electrolytics, or realising too late that their mains AC voltage measured at more than 10% over what was originally designed for.
There is no one view on what is appropriate.
Old 23rd October 2019, 03:59 PM   #20
disco is offline disco  Netherlands
disco's Avatar
The issue with direct coupled stages (that pull up the grid of the elevated tube at turn on) is that the elevated tube is fully conducting. That puts stress on its filament...
Do not have the intention to build DC coupled audio amplifier stages. If you want to design fast switching circuits with tubes then you have a point here.
Direct coupling is also beneficial to circumphere issues with marginal stable GNF and blocking distortion.
jaap
Shall I use a tube plate voltage delay?Hide this!Advertise here!
Tube amp high-voltage delay jan.didden Tubes / Valves 61 27th October 2019 03:52 AM
Plate voltage on preamp tube too high trombone Tubes / Valves 24 23rd July 2014 04:03 AM
Tube Plate Voltage Timing perpi Tubes / Valves 88 17th September 2013 02:03 PM
exceeding plate voltage of the output tube mdm102 Tubes / Valves 6 29th August 2011 01:17 PM
max plate voltage rating in tube datasheet jarthel Tubes / Valves 11 25th October 2006 05:24 PM
Copyright ©1999-2019 diyAudio
