Rogers Cadet MK3 using the Power Amp with a different Pre amp
Old 21st October 2019, 02:48 PM   #1
Farmerjake is offline Farmerjake
Default Rogers Cadet MK3 using the Power Amp with a different Pre amp
Hi All,
A while back I bought a Rogers Cadet MK3, it's the two piece pre amp & Power amp version. I've had it running for a couple of years now & love the sound but I recently saw a quad 33 in a hifi shop near me for fairly cheap & got me to thinking ....could I use a different pre amp with my Rogers power, would it sound any better/different, it would be an interesting experiment anyway.
The rogers has an umbilical which connects the two parts giving power to the pre plus the sound but it also the controls on and off to the whole setup. This is a 9 pin plug so wondering, is there a cable I can make that would allow me to try different pre-amps.
Old 21st October 2019, 04:48 PM   #2
Eli Duttman is offline Eli Duttman  United States
Look at the documentation. IMO, the hardest part of making the adapter cable will be sourcing the 9 pin plug. My guess is that a failed 9 pin mini tube will donate its base.
Eli D.
Old 21st October 2019, 08:09 PM   #3
Alllensoncanon is offline Alllensoncanon  United States
In addition to the cable that allow an RCA plug, you will need to do a couple of mod.
1. Short circuit the AC power and use a power bar or add a power switch.
2. Either add a dummy load to the preamp power pins (draw the same current as a the preamp sectio so it could be hot) or change R16 such that the preamp stage of the tube won't be over voltage.
Old 21st October 2019, 09:13 PM   #4
Galu is offline Galu  Scotland
Hi Farmerjake - may I interject a word of caution?
It could be argued that the magic of the Cadet Mk3 happens within the control unit with its trio of (as rare as hen's teeth!) ECC807 valves.
The power amp section may be described as being competent, but I don't see it as an ideal test bed for alternative pre-amps.
From one Rogers owner to another, allow me to say that I'd be inclined to leave this classic combo, the sound of which you love, well alone.
Old 21st October 2019, 11:20 PM   #5
gingertube is offline gingertube  Australia
I'm with Galu,
For my clock radio to wake me each morning I run a FM Tuner into my Cadet III driving a pair of vintage Warfdales.
Tried it with Tuner in via the tape DIN socket which bypasses most of the preamp and via the Radio Input which passes through all of the ECC807 preamp.
Definitely sounds better when feeding through all the ECC807s of the preamp.
Lucky those ECC807 last forever. Last time I tried to get some, the price was such that a if working on commercial considerations alone, then the Cadet III would have gone in the bin and the ECC807 pulls sold off. In fact that was the state it was in when I acquired it (no ECC807s).
Ian
Old 22nd October 2019, 12:41 AM   #6
Hi Ian!
I discovered exactly the same thing with my HG88 Mk3.
I feed my CD signal (suitably attenuated) into the 100mV tuner input. The CD sounds lifeless by comparison if connected to the less sensitive tape replay panel socket.
The HG88 Mk3 utilises four ECC807 valves and I thought that bypassing two of them by using the panel socket would sound best, but I was wrong!
My 807s are now 50 years old and functioning sweetly. Hope I never have to replace them as the going rate at auction is 100 to 150 for a single NOS valve.
Old 22nd October 2019, 11:18 AM   #7
Hi All, thanks so much for all the information & replies.
So, looks like:
A) As suspected this would be a leap to far beyond my limited technical skills (I can solder but not much else!)
B) I should stick with keeping it original & preserving the sound as is. I'll maybe just buy the quad as a separate setup.
I have two 807's as spares I chanced across not long after buying the amp & snapped them up for 40 for the pair so all good for what sounds like a lifetime of listening.
I generally listen to vinyl but do have my aux cable running through the tape input so thanks for the advice on that, i'll switch to the tuner.
@Galu & @gingertube any recomendations on speakers that pair well with the Cadet 3?. I currently have some Acoustic Research 4XA which sounded great with my Sansui AU101 amp but less so with the Rogers.
Old 22nd October 2019, 01:14 PM   #8
Both the AR-4ax and solid-state Sansui AU-101 hail from 1973 and would have been a good match electrically.
The speakers may not be as well controlled when powered by your mid to late 60s valve amp. Factors like damping factor, maximum undistorted amplifier power and speaker sensitivity come into play here.
The sensitivity of the 4xa is quoted on this site AR Speaker Specifications as 86dB.
There can be little doubt that contemporaneous speakers of a higher sensitivity would better match the low powered Cadet amp.
It appears that Ian uses Wharfedale speakers from the same era as the Cadet. I use full range, 12" Wharfedale RS12DD drivers (see attachment) which I purchased in 1969 along with my HG88 Mk3 amp. They are very sensitive and have a synergy with valve amps.
Are the foam surrounds of the AR-4xa woofers in good condition and has your Cadet undergone any renovation such as replacement of the electrolytic capacitors?
Old 22nd October 2019, 03:13 PM   #9
The AR's are in great condition but like you say they don't match as well as they do to the sansui.
The cadet is all in original condition other than a while back had a hum & a friend replaced one of the resistors, It's on my radar to do when I feel confident enough soldering or have the money to pay someone to do a good job.
When I saw your thumbnail I thought Oh My God I'm an idiot I saw a pair of these at a boot sale for 50 last year but then had a look around and it was the same as these: https://www.wilkinsons.tv/product/wh...i-speaker-kit/
(Probably still should have bought them!!)
Is there a factory built speaker that uses the RS12DD driver?
I also debated getting some Rega RS1 speakers as a friend has them with an old leak amp & they sound pretty good if lacking in bass slightly.
Thanks again
Old 22nd October 2019, 05:26 PM   #10
There's no factory built speaker that employs the RS12DD.
The Unit 4 is the kit version of the original Wharfedale Melton which was claimed to have a sensitivity of 89dB.
The Rega RS1 has a sensitivity of 90dB so would go loud on the end of your Cadet.
My Rogers HG88 Mk3 (big brother to your Cadet Mk3) sounded better than new after replacing the rectifiers, power supply and other electrolytic capacitors. The effectiveness of such components has improved over the past 50 years. This, however, is a job for someone with the appropriate knowledge, skill and safety awareness.
The voltages at various points in the circuit have to be measured and compared to those published in the manual before the amp can be given a clean bill of health.
Rogers Cadet MK3 using the Power Amp with a different Pre ampHide this!Advertise here!
Rogers Cadet MkIII pre and power amp adventure crusher007 Tubes / Valves 43 21st February 2019 07:39 PM
Rogers Cadet 3 Paul Rayson Tubes / Valves 3 7th January 2018 05:19 PM
Suggestions needed for improving Rogers Cadet II PP power amplifier Sanjiv Sahgal Tubes / Valves 10 23rd May 2012 10:26 AM
Rogers cadet 3 soulie12000 Tubes / Valves 8 29th January 2010 09:13 AM
Rogers Cadet III Power problem ? stephen_chrol Tubes / Valves 33 7th January 2007 11:04 PM
Copyright ©1999-2019 diyAudio
