Rogers Cadet MK3 using the Power Amp with a different Pre amp
Old 22nd October 2019, 09:52 PM   #11
Farmerjake is offline Farmerjake
Had a quick look around for some drivers & found a pair of the rs8dd around 45mins from my house. Which I think are the 8” versions. Do you think these would perform well? they’re currently in some huge cabinets that are a bit tired so could have a go at building some new enclosures if I can find some suitable plans. My living room is pretty small anyway so they never go up too loud.
Old 22nd October 2019, 10:26 PM   #12
Galu is offline Galu  Scotland
I assume we are talking Wharfedale Super 8/RS/DD (see attachments).
These would be the basis of a fun build.
They are very efficient (the magnets are the same strength as those on my RS/12/DDs) and work well in a 1cu ft (28 litre) enclosure.
I can supply the original Wharfedale cabinet plans should you decide to go ahead with the purchase.
Out of interest, what is the asking price?
Old 22nd October 2019, 11:09 PM   #13
Yes, they’re the above. They’re asking 145 or offers & say they’re in full working order. They have 2 different cabinet designs. The pic below is the larger.
Old 22nd October 2019, 11:13 PM   #14
Here are the Wharfedale cabinet plans: https://www.diyaudio.com/forums/atta...-dd-ccs-p3-pdf
Details of distributed port and reflex loading versions are given.
It is highly likely that the current enclosure for the 8" Super follows one of those versions.
P.S. Was composing this post while yours came in!
Old 22nd October 2019, 11:30 PM   #15
This pdf of a Wharfedale catalogue may be of interest. http://www.ajaudio.co.uk/Whafedale%20speakers.pdf
Old 22nd October 2019, 11:42 PM   #16
Originally Posted by Farmerjake View Post
They’re asking 145
The price of the Super 8 was £7 way back in 1962 - that's equivalent to £147 now!
Old 23rd October 2019, 07:57 AM   #17
Amazing!! Thanks so much, yes the other cabinet looks like it follows that plan but looks like it uses chipboard (See attached)
Old 23rd October 2019, 11:12 AM   #18
Will you be able to listen to these speakers before purchase?
Since you are interested only in the drivers, I suggest that they are removed from the cabinets prior to purchase so that you can inspect the cones from the front.
The tweeter cone has foam damping around its periphery which may have perished.
The foam can be replaced so it's not a deal breaker, but it may be used as a bargaining chip.
Old 23rd October 2019, 04:44 PM   #19
This site gives the sensitivity of the Super 8 as a whopping 93dB!
Wharfedale Super 8 RS DD Fullrange Loudspeaker Measurements Data and Information Full Range
The author has measured the Theile/Small parameters which could be used to design a reflex enclosure of a size more suited to your purpose.
Fs: 69 Hz
Re: 9 Ω
Qms: 4.52
Qes: 0.80
Qts: 0.68
Vas: 21.3 ltr
Le: 0.34 mH
P.S. In his conclusion, the author suggests a 'TWQT' enclosure. This acronym stands for 'Tapered Quarter Wave Tube'.
HiFi Loudspeaker Design
Old 23rd October 2019, 05:05 PM   #20
I'm afraid that a smaller enclosure than the one recommended by Wharfedale seems unattainable according to this vented box calculator!
Rogers Cadet MK3 using the Power Amp with a different Pre ampHide this!Advertise here!
Rogers Cadet MkIII pre and power amp adventure crusher007 Tubes / Valves 43 21st February 2019 07:39 PM
Rogers Cadet 3 Paul Rayson Tubes / Valves 3 7th January 2018 05:19 PM
Suggestions needed for improving Rogers Cadet II PP power amplifier Sanjiv Sahgal Tubes / Valves 10 23rd May 2012 10:26 AM
Rogers cadet 3 soulie12000 Tubes / Valves 8 29th January 2010 09:13 AM
Rogers Cadet III Power problem ? stephen_chrol Tubes / Valves 33 7th January 2007 11:04 PM
Copyright ©1999-2019 diyAudio
