JJ 2A3-40 for Lynn Olson Amity
Old 20th October 2019, 12:53 PM   #41
Tubenstein is offline Tubenstein
I just received a circuit diagram of Amity and both from the same date.
Both Lundahl LL9202AM and LL1620AM are adequate for Amity application. But I wonder which one is better for the application.
My friend says both Lundahl transformer can be made with air gap.
Any thoughts??
Old 20th October 2019, 01:42 PM   #42
indra1 is offline indra1  Indonesia
Why don't you read the datasheets and tell us what's on your mind?
Old 20th October 2019, 04:43 PM   #43
My friend told me LL1620AM is good as he is building the same amplifier.
Old 20th October 2019, 04:52 PM   #44
Something is in your mind you are not telling us. What concerns you?
Old 21st October 2019, 01:12 AM   #45
Hanze Khronye is offline Hanze Khronye  Australia
Originally Posted by Tubenstein View Post
What do you think 6.6K toroidal PP output transformer
I haven't had experience with them. I used LL1620 which was replaced with O-netics entry level 6k6.
Old 21st October 2019, 11:35 AM   #46
At first I consider to use Toroidy transformer with tentlabs autor-bias module to avoid the DC imbalance, however, if cost is put into consideration.
Sounds like the LL1620AM PP with air gap is a better deal as auto-bias module not cheap!
Old 21st October 2019, 01:00 PM   #47
Did you have LL1620 amorphous core?
Old 21st October 2019, 02:14 PM   #48
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
The AM version has one obvious advantage when introducing a meaningful airgap: there will be plenty of inductance left. Otoh i am not sure how great is Lundahl's idea of using the same size core when moving from steel to AM.
Old 21st October 2019, 08:07 PM   #49
Just the standard version.
JJ 2A3-40 for Lynn Olson AmityHide this!Advertise here!
Where's Lynn Olson's Ariel Website gone? tcpip Multi-Way 3 20th June 2004 07:56 AM
Lynn Olson's web site: AWOL? Kashmire Tubes / Valves 1 20th December 2003 04:41 PM
Ariel by Lynn Olson- How good are they really? Samuel Jayaraj Multi-Way 4 23rd November 2003 10:20 AM
Lynn Olson's ME2 Bas Horneman Multi-Way 16 25th October 2002 03:01 PM
FS: Ariels - Lynn Olson design bbaker6212 Swap Meet 3 2nd October 2002 06:18 AM
Copyright ©1999-2019 diyAudio
