Tube amp high-voltage delay
Thread Tools
Old 27th September 2021, 07:29 AM   #81
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Overengineering 101. The NTC does a good job in all circumstances. Probably too simple and too effective
It's only audio. Member of the non modular PCB design committee.
Old 27th September 2021, 08:03 AM   #82
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
NTCs are boring for an audio diy-er JP!
Jan
Old 27th September 2021, 08:03 AM   #83
jean-paul's Avatar
Look at tubes
Old 27th September 2021, 08:07 AM   #84
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
NTC's are about as simple as it gets...aside from NTC's i also stick in an MOV across the power traffo primary...
Old 27th September 2021, 11:56 AM   #85
JoeAlders is offline JoeAlders  Netherlands
MOV ?? What is it?
Old 27th September 2021, 12:01 PM   #86
TonyTecson's Avatar
Originally Posted by JoeAlders View Post
MOV ?? What is it?
mov electronics - Google Search
MOV electronics
A varistor is an electronic component with an electrical resistance that varies with the applied voltage. Also known as a voltage-dependent resistor (VDR), it has a nonlinear, non-ohmic current–voltage characteristic that is similar to that of a diode. ... This type is commonly known as the metal-oxide varistor (MOV).
Varistor - Wikipedia).
Old 27th September 2021, 12:24 PM   #87
NickKUK is offline NickKUK  United Kingdom
Originally Posted by Mark Johnson View Post
Then it might be a nice idea to have the sequencer switch the mains at a voltage peak, both switch-on and switch-off.
You’ll probably want to cover brownout and mains cable disconnect/reconnect like an intermittent mains outage.
V1 - low gain tube HPA OTL, fully balanced cascode 12BH7A, 12BH7A CCS, 12BH7A drivers and ECC99-BJT hybrid circlotron. (build)
V2 - pure digital tube HPA, RF-tube DSD512 modulation with mosfet output stage. (initial design)
Old 28th September 2021, 02:02 AM   #88
TonyTecson's Avatar
^with arduino, imo that is possible with the right sensors...
Old 30th September 2021, 10:05 AM   #89
jan.didden's Avatar
Some info on how to select NTCs for transformer inrush protection.
Read especially the 1st para, saying that you should not switch on at zero crossing! I have been preaching that for years, only to be cut down for it ...
Jan
Old 30th September 2021, 10:14 AM   #90
jean-paul's Avatar
Common knowledge on dutch technical schools decades ago. Anyone reading Elektuur/Elektor knew this too.
It seems today some people search for complicated ways to solve non-issues already solved a long time ago. Or, worse, to find a new way of doing things that is way worse than the old method. On this forum one can detect some design errors in designs that are accepted and defended.
Nah, quality and efficiency are boring
Tube amp high-voltage delayHide this!Advertise here!
Thread Tools
High voltage delay circuit exeric Tubes / Valves 31 21st January 2016 06:35 AM
Plate voltage on preamp tube too high trombone Tubes / Valves 24 23rd July 2014 04:03 AM
High voltage power tube question hahfran Tubes / Valves 8 10th February 2014 07:03 PM
FOR TUBE: 350V High Voltage Regulator uhcmos Swap Meet 26 6th February 2010 05:28 AM
FOR TUBE: 350V High Voltage Regulator uhcmos Tubes / Valves 0 31st May 2008 12:49 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
