DIY McIntosh Amp
DIY McIntosh Amp
Old 18th October 2019, 08:54 PM   #211
cerrem is offline cerrem  United States
cerrem's Avatar
Originally Posted by 6A3sUMMER View Post
academia50,
jhstewart9 di mark the Phase of the windings in the drawing.
An oscillator and a 2 channel scope, are all that is needed to test the relative phase of any 2 windings (and all the windings).
It pays to do this kind of test, I have had commercial transformers that are marked wrong.
And that goes for Tweeters phase that is mis-marked too, but that is a more difficult test.
Another tactic is to put the windings in series.... The measure the AC voltage to see if it is adding or subtracting....this well tell you the phase relative to your reference winding...
Old 18th October 2019, 08:57 PM   #212
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
Originally Posted by academia50 View Post
Cerrem, with your permission:
Hearinspace, you have to identify each winding, and also, I suppose it is also important to identify where it " comes in " and where it " comes out " . Once closed, you cannot do it by measuring resistance only.
Correct if I am wrong, the PDFs are very good but translating them is a pain, you have to copy, paste in the translator, etc.
Thanks anyway, jhstewart9
Not sure what to make of this post, looks to be signed by me.
Response to two of us maybe?? Or three??
The PDFs I posted all opened for me on the forum, so I guess OK!!
Old 18th October 2019, 09:12 PM   #213
jhstewart9's Avatar
Hammond provided the info I needed to get the primary connexions correct the first time. How cool is that!! And what we would expect anyway. Thru buz connexionz I knew several guys at Hammond, not far from where I live.
Just took a look at another H300767, new right out of the box. All eight primary leads & five secondary leads are brought out. So no problem with resistance measurements.
Just gotta make time to do that now.
All the several projects I did back then were strictly experimental. During my time as a sales & apps guy with HP & others I had been curious about some of the not so obvious toob amp circuits. This was one of those. The results were good, so I moved on. Except for a temporary hookup the amp was never set up to listen to at all. The amp was strictly a 'Proof of Concept' project.
Old 18th October 2019, 09:27 PM   #214
academia50 is offline academia50  Argentina
academia50,
I have managed to see the movement (minimum, of course) of the cone in a tweeter with the method of the stack and observing with a magnifying glass ..... but some do not accuse any perceptible movement ....
If the ends of the windings are not marked to know in which direction the turns advance, is not the same as not knowing the phase?
The first valve amplifier I assembled was the classic one I attached here known as "Silco".
I remember that he had hum, and he changes (uselessly) the OPTs believing they were to blame ... but the manufacturer attached the leaflet with the wiring and all the colors of the cables.
In those years (1967) the solid state began to "make noise", so assemble the classic RCA of quasi-complementary symmetry. The idea was to copy the MC Intosh MA6100! So to make it less complex, I decided to build the power and the preamp separately. At that time around here there were people who made the transformers to order, and did a good job.
I ordered EI oriented grain sheets, the winding attached to the middle for the two sections of the RCA (+ and -) and a 110 volt branch for the preamplifier.
The amplifier still works perfectly, the pre could never finish it.
I would have to upload some photos in the corresponding thread ....
Here is something ...
Preamp MC Intosh MA-6100 (DIY)
Old 18th October 2019, 09:32 PM   #215
I addressed all three, I'm sorry if it wasn't clear ......
I must not save post, obviously ...
Old 18th October 2019, 09:37 PM   #216
academia50,
I didn't see that .... I'm retired from these leagues and some things are missing me, I'm sorry
Old 18th October 2019, 09:42 PM   #217
Good advice, your OPT look great, sorry for intruding me, I just wanted to participate a little and alert (if not a troll) to MC240 ....
Old 19th October 2019, 12:16 AM   #218
jhstewart9's Avatar
Default Realistic Audio Engineering- Crowhurst
Norman Crowhurst on UC. Audio Magazine Oct 1959
Old Yesterday, 10:45 AM   #219
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by smoking-amp View Post
note:
I think the MC3500 was running with 475V B+, efficiency will be a little lower at 450V B+ here. The MAC was probably using around 260 Ohm Zpri (one side) (4 x 260 = 1040 Ohm P to P ) [ R = 425V x 425V / (2 x 350W) = 258 Ohm ]
Also, the knee V for PL519 drops to around 50 V at the lower peak current used now. (450V -50V = 400V delta) Screen V can be lowered until peak current can just be reached, that will lower the knee V further and improve efficiency.
So let's see: R = 400V x 400V / (2 x 400W) = 200 Ohms.
So 200 Ohms looks better for Circlotron Zprimary with the 8 x PL519 at 450V B+, and 400 Watt output.
For 350 Watt output at 450V B+: R = 400V x 400V / (2 x 350W) = 228.6 Ohms
I'm quite sure that I've read in one of the threads concerning the MC-3500/MI-350 that it's OT transforms the load to an effective primary impedance of 600 ohms, i.e. (1) 2400 ohms per tube pair, i.e. (2) 150 ohms per cathode and plate winding.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old Yesterday, 08:02 PM   #220
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Yes, those numbers do sound familiar. Apparently the Mac can do much more than the rated 350 Watts for short intervals. Like 600 Watts from those #s, so 350 Watts must be a steady sine wave power spec.
Peak Watts = 1/2 x (475 -50) x (475 - 50) / 150 = 602 Watts for short intervals (close to max tube steady state Pdiss for class B)
So, allowing for the so called audio "Crest Factor", one can design the OT and B+ for almost twice the steady state Watts (at least). (George - Tubelab probably would give an even more generous allowance factor, depending on music type) The spec'd low freq. end of the OT may not fully support such a large surge rating however.
Well, then the OT for a Circlotron should allow for the same "Crest" factor at least also. From the MC-3500 150/258 = 0.58 factor for the primary Ohms below the allowed steady state calc. (from total tube Pdiss) Or, equivalently, just design for max tube dissipation in class B and then derate the avg power rating by 40% for reliability. (20% to 30% derating may be more typical)
DIY McIntosh AmpHide this!Advertise here!
Mcintosh C200 service manual : why it is so hard to get it from Mcintosh ? blackgotan Solid State 1 12th March 2016 11:07 AM
Mcintosh C28 Hum Rudes Solid State 20 9th May 2013 08:58 PM
McIntosh C-24 wanders Solid State 9 6th September 2012 06:21 PM
mcintosh pcb 043-899 lizo Parts 0 8th February 2012 10:36 PM
SE amp like mcintosh ? jeapel Tubes / Valves 20 29th March 2005 01:47 PM
Copyright ©1999-2019 diyAudio
