Using zeners for G2 regulation
Old 23rd September 2019, 10:12 AM   #31
disco is offline disco  Netherlands
disco's Avatar
Perhaps you observe the loading of a bypass cap at G2? For best regulation current excursions need to be as low as possible (against heating up), that's where the BJT (or FET) is of aid.
When you observe the dynamic properties of a sole 1N5377B, its impedance is 760 ohm at 1 mA, dropping to 75 ohm at 15 mA, while the maximum regulator current is 52,5 mA. A bypass of 1uF will ride along with G2 voltage at any signal level.
Using zeners for G2 regulationHide this!Advertise here!
Regulating battery to 9V Nicho Power Supplies 27 10th April 2013 11:16 PM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Self regulating Class A Kees Solid State 50 14th October 2004 08:41 PM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 09:42 PM
7815 not regulating. JoeBob Solid State 16 8th September 2003 12:51 PM
Copyright ©1999-2019 diyAudio
