Cutting open vacuum tubes - dangerous?
Old 20th September 2019, 09:58 AM   #21
TBTL is offline TBTL  Germany
Do you plan on making the filament glow? Then you somehow need to restore the vacuum and reseal the tube. The filament needs a vacuum to prevent it from burning out.
Old 20th September 2019, 12:29 PM   #22
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Giant fake tube
Old 21st September 2019, 06:56 AM   #23
hpeter is offline hpeter  Slovakia
hpeter's Avatar
barium/strontium/calcium oxides cathode; barium flash getter; thats the biggest health risk imo. mercury filled tubes are other story.
rest is nickel,copper,carbon,molybden,tungsten,mica,glass.
about beo-its the pink ceramic,like in magnetrons.
..BLOG.. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000Ķ // 4-125a test
Old 22nd September 2019, 05:28 PM   #24
opcom is offline opcom  United States
opcom's Avatar
Originally Posted by Eli Duttman View Post
The white of knackered getters is reactive metal oxide. Add water and the result is alkaline.
Ah a modern city then, but alkali rain instead of acid rain!
P.S. will the hot wire (string) method work on vacuum tube glass? It is more resistant to temp. stresses than a bottle..
Cutting open vacuum tubes - dangerous?Hide this!Advertise here!
Vacuum Tubes siliconray Siliconray Online Electronics Store 2 11th October 2011 11:29 PM
Vacuum tubes, vacuum capacitors and vacuum relays GREENSTONE USA Vendor's Bazaar 0 19th August 2011 03:38 PM
DIY vacuum tubes! sss Tubes / Valves 1 17th January 2008 12:49 AM
A-openís new motherboard with vacuum tube preamp LBHajdu Tubes / Valves 10 5th August 2002 01:40 AM
Copyright ©1999-2019 diyAudio
