Glossary
Glossary
Old 16th September 2019, 10:37 AM   #11
Ketje is offline Ketje  Belgium
Ketje's Avatar
Without the schematic it is still not very clear.
I would write it like A = µRa / [ Ri + Ra + ( µ+1 ) Rk ]
Since it's about gain, it's obvious that µ and Ri are dynamic values as in µ=S.Ri
Mona
Old 16th September 2019, 11:53 AM   #12
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Glossary
Greetings! Symbols were a great deal less standardised than today, especially across geographic variations. Ketje is using the Philips symbols, which appear in a large amount of literature from Europe (snapshot attached from the Philips technical manual).
Still, even within Philips, this is not held consistently. Mullard was a Philips company, but their 1948 data book defines anode resistance symbols as
ra (inside valve)
Ra (outside valve)
Marconi Osram (1951 data) uses this same standard. But before we can say that British manufacturers were consistent, we find that Brimar used R for loads and Ra for internal anode resistance.
You really have to know in advance what the writer meant by any symbol in historical literature, or at least carefully figure it out.
For drawing new schematics or design-definitions, the small-signal & large signal conventions that Rayma links to are widely used in modern electronics, and are far preferable, IMHO. So Ra, Za, Rp, Zp for external loads (small signal values), and ra (or rp) for internal small-signal resistance are examples of my preferences.
Old 16th September 2019, 04:23 PM   #13
rayma is offline rayma  United States
Originally Posted by Hearinspace View Post
Thanks for that. It makes it clear and easy to remember ,
. . . . . though it still bugs me a little that we can't use the notation to learn the principle, we have to already know the principle in order to interpret the notation. I don't like the idea much.
Stick with more recent books and it should be more consistent.
Old 16th September 2019, 05:56 PM   #14
Ketje's Avatar
Using lower case for AC and upper case for DC parameters is not as simple as that.
In the formula A = µRa / [ Ri + Ra + ( µ+1 ) Rk ], Ra and Rk doesn't have to be only for DC.
Ra can not only be the actual resistance to + but parallel to it the (capacitor coupled) grid resistor of the next stage, or a transformer or even a CCS.
Same thing for Rk, a LED or a CCS...
Then there also is the possebility of a filter as a load.
More exact would be A = µZa / [ Zi + Za + (µ+1) Zk ], yes also Zi because of anode capacity.
Conclusion, better explane the variables before using them.
Mona
Old 16th September 2019, 06:01 PM   #15
DF96 is offline DF96  England
Yes. Useful symbol conventions aid understanding, but they are not physical laws.
Old 16th September 2019, 07:10 PM   #16
kodabmx is offline kodabmx  Canada
Spreading triode love.
Glossary
I feel the same about current... In my mind (and in reality), current flows from negative to positive. "Conventional" current should be called "anti-current" IMHO.
Old 17th September 2019, 04:12 AM   #17
PRR is online now PRR  United States
PRR's Avatar
...it still bugs me a little that we can't use the notation to learn the principle, we have to already know the principle in order to interpret the notation....
Because history. Techs had to fumble with the "principle" before they could do "notation" (to know what to notate).
And as said, there was not universal agreement on notation. Read electronics magazines of old. From the 1930s through the 1960s there were many "recommendations" in the US, and different ones in Europe etc. (The change from mmf thru uuf to pF happened much earlier in much of Europe than in the US.) The IEEE has been working for harmony, but each clique clings to habit, and nobody of universal respect is harmonizing small-tube notation today.
GlossaryHide this!Advertise here!
GLOSSARY... Where do you find it? stereodude27 Everything Else 1 19th October 2011 12:02 PM
Glossary for abbreviations - Help! crispycircuit Everything Else 1 3rd February 2010 11:06 PM
Gainclone Glossary Ropie Chip Amps 0 28th April 2004 10:13 PM
POWER AMP Glossary chris ma Everything Else 0 22nd October 2003 05:24 PM
Copyright ©1999-2019 diyAudio
