Grid stopper resistor question
Old 17th September 2019, 02:53 PM   #41
DF96 is offline DF96  England
Originally Posted by SemperFi
Can a cathode follower oscillate the same way?
It is well known that all followers are prone to oscillation, especially with a capacitive output load. The usual solution is an output stopper, to isolate the output from the capacitance. Inductance does no harm.
To me I see no reason not to place the gridstopper right at the pin, and the reason is to limit unwanted inductance, as well as having a logical and consistent place to have it.
Yes, put it at the pin. But not for the reason you say.
It may be rules of dumb but I have had MF gridstoppers open up after over-drive in guitar amps. CCs have never failed, they are simple the most tolerant resistor types. And the horrid drift doesnt matter in this application, so I see no reason not to adhere to this rule made up by much wiser men than me.
When following a rule made up by wiser men it helps to know why they invented the rule; then you will know when you don't need to follow the rule. CC resistors are good at coping with temporary overloads, so they may be useful in a guitar amp output stage suffering from heavy overdrive. This reason does not apply to hi-fi, so there is no need to use CC stoppers elsewhere.
Old 17th September 2019, 03:23 PM   #42
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Clapp and Hartley oscillators can use a follower.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Grid stopper resistor questionHide this!Advertise here!
Specific grid stopper question optimationman Tubes / Valves 22 10th March 2013 08:22 PM
grid stopper question - 300B TubelabSE discomonkey Tubelab 6 28th April 2011 04:32 AM
Grid stopper resistor for 12B4A? G Tubes / Valves 9 16th May 2009 05:19 PM
Grid stopper resistor required (KT66)? porkchop61 Tubes / Valves 24 18th March 2008 09:18 PM
grid-stopper resistor krusty75 Tubes / Valves 2 7th March 2008 12:24 AM
Copyright ©1999-2019 diyAudio
