Grid stopper resistor question
Old 13th September 2019, 01:17 PM   #11
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by sumotan View Post
Your comment that grid stopper resistor does not affect sound got me curious DF96.
Why would it not be when this resistor is directly in the signal path.
Everything affects the sound.
However, in most cases it is negligible.
PCBCAD51 download or CDROM October 2019 version out now ..https://www.murtonpikesystems.co.uk
Old 13th September 2019, 03:35 PM   #12
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
I've read that some have used surface mount resistors soldered direct to the socket terminal. Thus, very short leads.
Old 14th September 2019, 02:29 AM   #13
PRR is offline PRR  United States
PRR's Avatar
...grid stopper resistor does not affect sound got me curious ...Why would it not be when this resistor is directly in the signal path....
The resistor is 1k or so.
The tube grid is over 100Megs over most of the audio band.
Look at it like a Voltage Divider. Huge variation of the resistor make "NO" difference to the voltage on the grid.
A high-Mu triode grid may come down past 200k at the top of the audio band. Still a few-k resistor makes about no difference.
Anyway carbon-comp is not THAT bad. It's all we had for decades.
Old 15th September 2019, 01:16 AM   #14
Hanze Khronye is offline Hanze Khronye  Australia
I realise there is no DC current through this resistor yet I wonder about contribution of noise from this resistor, 12AX7 is a high mu tube. Contact, thermal, Shot and or Johnson noise?.
Would a ferrite bead be a better solution?. 9 pin tube socket, cut the grid lugs down the centre, slip ferrite over the socket pin, solder to the lug tip.
If all we are doing is creating a LP filter, why not small value cap in parallel with the grid leak resistor?..
Anyway, I'm interested to see where this goes.
HK
Old 15th September 2019, 01:25 AM   #15
PRR's Avatar
Hiss from a ~~1k resistor at line level?
Do math. It's quite negligible.
FWIW: the hiss voltage at 12AX7 grid is OTOO a 20k resistor.
Old 15th September 2019, 01:55 AM   #16
I wasn't assuming line level, and what is hiss voltage?
Old 15th September 2019, 03:24 AM   #17
dotneck335 is online now dotneck335  United States
Originally Posted by SemperFi View Post
Musical instrument amplifiers are often over driven (mostly guitar) and in those cases carbon comp is usually preferred, not just for their great pulse- and overload-tolerance, and non inductive properties, but also for sound. Carbon comps are the best for this purpose.
Originally Posted by JonSnell Electronic View Post
Grid stoppers are best if they are carbon composition.
I am still not getting why the carbon comps are BETTER as a grid stopper resistor than a metal film one. WHAT makes them SOUND better?
Old 15th September 2019, 04:25 AM   #18
Why don't you build something, find out for yourself. Most of us have. And if you don't, then why come here with such comments?
Old 15th September 2019, 04:54 AM   #19
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Grid stopper is needed only and only if the stage is unstable without it. Sometimes it even does harm, from example in a first stage of a power amp that has feedback to it's cathode, where a capacitor around 100 pF to the ground my work better. Sometimes it plays also other roles, like much bigger value resistor at input of a guitar amp, to work as a filter. Or, in the grid of output tubes where it increases time constant of a coupling capacitor when it's being charged through the grid current on overload.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 15th September 2019, 06:03 AM   #20
100R + ferrite keeps high Gm and Mu from oscillating, I don't know how or why.. but it works, take away 100R and it oscillates. I'm not sure its strictly LP filter, suspect there is more to it than that. Low level <200mV.. as always could be wrong. Just saying from real world experience.
Grid stopper resistor questionHide this!Advertise here!
Specific grid stopper question optimationman Tubes / Valves 22 10th March 2013 08:22 PM
grid stopper question - 300B TubelabSE discomonkey Tubelab 6 28th April 2011 04:32 AM
Grid stopper resistor for 12B4A? G Tubes / Valves 9 16th May 2009 05:19 PM
Grid stopper resistor required (KT66)? porkchop61 Tubes / Valves 24 18th March 2008 09:18 PM
grid-stopper resistor krusty75 Tubes / Valves 2 7th March 2008 12:24 AM
Copyright ©1999-2019 diyAudio
