Broskie 12VAC aikido board with 6n1p tubes
Old 12th September 2019, 03:18 AM   #1
Sadface is offline Sadface  New Zealand
Default Broskie 12VAC aikido board with 6n1p tubes
Hi Guys,
I've been looking at building a 12vac aikido board and I am wondering if anybody has tried running 6n1p tubes with a 12vac board?
I ask because 6n1p tubes are cheap and plentiful in my neighborhood whereas 6dj8s are not.
I frequently see 6n1p tubes sold as a 6dj8 replacement but I also understand this is not strictly true.
I will freely admit that I don't yet understand enough about triode curves to answer this question myself off the spec sheet.
Old 12th September 2019, 07:34 AM   #2
tikiroo is offline tikiroo  New Zealand
Hi Sadface, I've got no experience using 6n1p but looking at the curves it seems that they aren't particularly suitable for use at low voltage (12v ac Aikido has each tube at about 40V I think). Current will be low and distortion high. Perhaps you should go for 6n6p instead which looks much better at low voltage. Although TradeMe has 6n1p @ $10 a pair vs $25 a pair for 6n6p.
Old 12th September 2019, 01:06 PM   #3
Steve Morley is offline Steve Morley  Canada
Both the 6n1p and the 6n6p draw a lot more filament current than a 6DJ8. The power supply on12Vac board is a "multiple" voltage multiplier with taps for filament at one level and B+ at a higher level. The PS might not respond well to the extra filament loading. There might be more ripple on the B+? You might need a larger power trans as well
Aside form the lower B+ (~80 volts) not working with the 6n1p and 6n6p you won't have many tube rolling options with these.
If you haven't bought the Broskie kit yet he'll sell you, as an option, four JJ E88CCs for $56.
A cool NOS tube that is reasonably priced (for NOS) is the Tesla ECC88. They kind of remind me of the Mullard Blackburn ECC88 with a more rock 'em, sock 'em sound than the JJs.
Steve
Broskie 12VAC aikido board with 6n1p tubesHide this!Advertise here!
Aikido 12Vac yakusa Tubes / Valves 34 27th January 2016 08:32 PM
FS: Broskie (glass-ware) Aikido 12vAC Preamp - fully assembled Metropolis Swap Meet 3 23rd June 2015 01:49 AM
Aikido 12vac cbutterworth Tubes / Valves 9 25th January 2015 12:45 AM
Experimenting with the Aikido 12Vac kit Steve Morley Tubes / Valves 1 23rd January 2015 06:39 PM
LM3875 (Audio sector) + Aikido 12VAC or Aikido ACF-2? Sodacose Chip Amps 30 28th August 2013 09:28 PM
Copyright ©1999-2019 diyAudio
