100 Hz hum Kora Explorer 90SII CSC
Old 11th September 2019, 09:15 AM   #21
baudouin0 is offline baudouin0
OK super glad we were of help just shows - poor PCB tracking.
Old 11th September 2019, 10:23 AM   #22
DF96 is offline DF96  England
The mystery is why other examples of this amp don't have hum, given the elementary grounding mistake in the PCB design.
Old 11th September 2019, 10:26 AM   #23
Depaj is offline Depaj  France
I did some more research in french and read some people complaining about a slight hum but they described it more like 50Hz, it's probably the same thing though. Those saying it was very quiet might have had pretty inefficient speakers.
Old 11th September 2019, 11:58 AM   #24
You can probably leave the cap on the board. Drill the holes out where the diode grounds were and pass wire from the diodes (with heat shrink) through the PCB soldering directly onto the ground of the cap on the underside of the board.
Old 11th September 2019, 12:09 PM   #25
The ground pads were actually connected through 4 tiny little tracks to the ground plain so I just cut these out and left the pad isolated, then ran some nice thick insulated copper wire to make the necessary connections.
Old 11th September 2019, 01:05 PM   #26
Thermal relief.
100 Hz hum Kora Explorer 90SII CSCHide this!Advertise here!
The A.N.T. Audio Kora 3T Phono Stage circuit published. x-pro Analogue Source 52 31st March 2018 12:05 AM
KORA Mercury Schematic Diagram - LORLIN Rotary Switch replace by ELMA 04 tiefbassuebertr Parts 2 25th May 2017 07:50 AM
A.N.T. Audio Kora 3T phono stage DIY kits available x-pro Vendor's Bazaar 0 19th December 2012 09:32 AM
Kora Equinoxe Triode or Blue Circle BC-21.1 preamp? RAART Tubes / Valves 0 9th August 2012 04:00 AM
Internet Explorer 6.0 Christian Everything Else 154 10th December 2002 09:18 AM
Copyright ©1999-2019 diyAudio
