New build: 6F12P - 6N8S - 6P36S triode push pull.
Old 16th September 2019, 10:48 PM   #31
kodabmx is offline kodabmx  Canada
Spreading triode love.
Ok. One more update to the design.
I added an RC filter to the main power supply. This reduces ripple to ~8mV.
I also cleaned up and corrected the main schematic. The grid stoppers are in the right place now, and the values are correct.
I rewired the entire rack today, and chased some hum away in the process. Results!
Koda
Old 16th September 2019, 11:48 PM   #32
Question for those among us with "mathing" skills.
If Ra-a=4300 and screen taps are at 40%, does that mean Rs-s = ~2000? I'm looking for a way to get lower Ra-a from these but still be able to switch 4R or 8R secondary instead of using 16R for 6R to reflect the lower Ra-a.
Old 17th September 2019, 01:20 AM   #33
tikiroo is offline tikiroo  New Zealand
Screen taps are shown as % of turns. Impedance is related to the square of the turns ratio. So 40% of the turns on the primary corresponds to 16% of the impedance ratio. So Rs-s would only be 688
Old 17th September 2019, 12:44 PM   #34
Which coupled with the max current of 318mA, is quite useless
Thanks though.
New build: 6F12P - 6N8S - 6P36S triode push pull.Hide this!Advertise here!
6F12P and 6P43P push pull triode amp kodabmx Tubes / Valves 11 3rd November 2019 12:43 AM
12AV5GA push pull triode amplifier. kodabmx Tubes / Valves 22 13th November 2018 12:22 AM
6L6 Triode AB Push/Pull Pout famousmockingbird Tubes / Valves 18 10th March 2015 09:00 PM
Push Pull DHT triode James D. Tubes / Valves 14 8th April 2004 04:43 PM
DHT triode push pull amplifier design James D. Tubes / Valves 2 5th December 2002 09:44 AM
Copyright ©1999-2019 diyAudio
