Build GU50 PSE
Build GU50 PSE
Old 16th September 2019, 05:16 AM   #21
Sadface is offline Sadface  New Zealand
Trade Me there is a kit set available
Old 16th September 2019, 07:52 AM   #22
K.A.B is offline K.A.B  Sweden
K.A.B's Avatar
Why triode?
GU50 is not that bad as pentode in pentode you will get all the power you need. If you go for triode try schade feedback then.
Old 16th September 2019, 08:28 AM   #23
davorin is offline davorin  Croatia
Two pieces of GU50 in PSE junction can deliver more than ~ 35W output power with very little internal resistance and low primary anode impedance (~ 1-1.25kOhms). With Shade feedback and a THD distortion criterion of ~ 2% output power can be greater than 25W (up to 30W!) so you should definitely try something like this.
Build GU50 PSEHide this!Advertise here!
Another PP GU50 matejsirk Tubes / Valves 16 9th May 2013 06:30 AM
Help~ GU50 ? maxxtro Tubes / Valves 3 2nd October 2012 07:01 PM
My little SE with GU50 matejsirk Tubes / Valves 20 28th January 2012 03:27 PM
Gu50 cristelu2006 Tubes / Valves 13 18th November 2009 10:29 PM
Gu50 Set ? pwan Tubes / Valves 3 22nd April 2007 04:15 PM
Copyright ©1999-2019 diyAudio
