Plate temperature measurement
Old 31st August 2019, 10:11 PM   #1
pcbampmaker is offline pcbampmaker  New Zealand
Default Plate temperature measurement
Hi all,
I will start admitting I may have been following a white rabbit passing by a little too far. Maybe. However:
I have recently restored/rebuilt a tube amplifier (it happens to be a guitar amp, but you'll see in a moment that won't make much difference to this question) and as I was checking it was all rebuilt well, I set up the bias levels and took a quick look at temperatures of various components all around the amp. This I've done relatively casually using a FLIR i7 thermal imaging camera (a very fun device). I'm a bit fretty because I used a heater wiring that has insulation in PVC and I was concerned it might have heat trouble.
As I was looking around things, I noticed that the plates of the output tubes (a quad of 6L6GC's) read as having a hot spot of approx 160C near the center. The idle current is 40mA and the center tap of the output transformer is 450V, so that the plate is dissipating 18W at idle.
Now the question: if I understand correctly, the only way the plate has to dissipate 18W is to radiate heat away, because the vacuum impedes convective flow, and the pins will do some conduction, but not enough to worry about it.
Indeed the FLIR says the pins on the socket are at approximately 37C, some 15-20C above ambient, but not much heat flow there.
However, applying Stefan-Boltzmann's law to the plate body, it seems you get a dissipation rate of about 5.5W, which really makes no sense to me.
Here's my reasoning:
- heat dissipated is \sigma T^4 [W/m^2]
- \sigma ~= .85 (which I think is high as an estimate, because the plates are dark, but far from black, and eyeballing them they don't look very rough)
- T = 160C = 440.15K implies we get 2128W/m^2
- the area of the plate on a 6L6GC is approx 32cm^2: it's 32mm tall, and seems to be approx 50mm wide if you sum the width of the front, side and "stitching" surfaces, then double for front and back
- the glass will absorb some IR for sure. On the one side you'd think the manufacturer goes out of their way to minimize this effect, on the other maybe they're just using moderately priced glass after all. The expectation is that the envelope will then do a combination of radiation (small, it's very shiny, and shiny things have low \sigma's) and convection through air
Some fine print:
- when computing the plate area you only need the external facing surface of the plate, but not the inner one. That one radiates onto the inner side of the plate opposite from it, which then absorbs it.
- Whatever reflection is left from said inner surface goes back to the emitter and so on. This is like a radiation furnace. There will be some heat escaping top and bottom, of course, but I doubt that'll be more than say 20% (the micas tend to be lightly coloured, and seem to stay much colder judging from the FLIR's reading)
- Note that using the full area as if it was all at peak temperature is also an over estimation: there is no way the "stitching" sides are anywhere near this hot, and even the plate "proper" has a clear temperature gradient across it, about the shape you'd have in a red-plating tube. This is expected because it's where most of the electrons actually hit it, and I'll bet a major component of the gradient is actually heat conduction in the metal
- about the glass: the emission spectrum can be plotted here: at 311C the peak is at 5um, at 170C it's maybe closer to 6.5um. Judgin from this plot, around 5-6um the absorption is just under 5% per mm thickness (maybe 4%?). I haven't checked but I doubt a 6L6 has an envelope thicker than 1 mm
It seems that to radiate away 18W you'd need a plate that is at an *average* temperature of 311C (likely more, because as I said, I don't believe the \sigma estimate is low enough).
Can anybody explain this? I really feel like I'm missing something obvious here.
Thanks for whatever insight you might share
Old 31st August 2019, 11:49 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Canīt "explain" anything, specially because I would need more data, but:
In principle,having just a hot spot reaching mere 160C and it being just a small fraction of total area, makes me think 2 things:
* your meter o measuring technique has some error, period.
* or tube is dissipating less than you think
plus one factor which might explain significative differences:
I think you assume IR leaving plate surface at a 90 degrees angle ... in which case it would irradiate in a cylindrical shape, same height as the plate "cylinder" , while I guess each surface point irradiates in a diffuse omnidirectional way.
Whatīs my point?
If IR were visible light instead , you woukd be able to see a glowing plate structure anywhere you look from, solid 360 degrees around, ... just not uniform intensity depending on "visible surface" from observerīs point of view.
Meaning an important part of IR radiation is escaping all over the place and not just towards IR meter lens or window.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 1st September 2019, 12:49 AM   #3
PRR is offline PRR  United States
PRR's Avatar
For our purposes, heat comes off a tube by *convection* from the *glass*. {edited from "convention"}
Soft glass can't run hot enough for radiation to be significant.
Power-tube glass is often rated 250 deg C max envelope temperature.
Yes, heat flows from plate to glass mostly by radiation. My experience is that a FLIR can't see through glass, but reads the glass temp (and often incorrectly unless you paste some paper on it).
Last edited by PRR; 1st September 2019 at 01:19 AM. Reason: *convection* from the *glass*. {edited from "convention"}
Old 1st September 2019, 01:07 AM   #4
Duke58 is offline Duke58  United States
Heat comes off the tube by convention or convection? Do you think the FLIR can't read through the glass because the light is diffracted?
Old 1st September 2019, 02:17 AM   #5
rayma is online now rayma  United States
Is the tube's glass envelope transparent to infrared light, or not?
I'd say not much, since the glass gets pretty @#&^%#$! hot
from the radiation from the plate.
Old 1st September 2019, 02:32 AM   #6
* your meter or measuring technique has some error, period.
Possibly, although I'm not so sure how that would happen (see below). In other words: clearly there is some error, the question is where, what error, and why
Well yes. This is a fair point to make. So here's my setup: I'm measuring voltage drop across the OT windings to measure current and voltage to ground from the center tap to measure plate voltage. Then I'm using the difference of the two for actual plate voltage, and the voltage across the winding divided by the cold resistance to measure current.
I own two Fluke 8840a meters (5.5 digits, calibrated a couple years back, admittedly), but for this particula setup I used a couple 3.5 digits handheld meters (because they're handier). They seem to be in passable agreement with the Flukes (by a rather random "double check a couple voltages, say 10, 50 and 200V" test). So I'd think this is "ok", say within 20% of truth.
Whatīs my point?
If IR were visible light instead , you would be able to see a glowing plate structure anywhere you look from, solid 360 degrees around, ... just not uniform intensity depending on "visible surface" from observerīs point of view.
You make a reasonable hypothesis, but I don't think this can be the case: the FLIR is designed to measure <something, see "gory details" below> and from that reconstruct temperature, if there were pronounced geometric sensitivities the instrument couldn't be used.
I was more inclined to think along the lines that the spectral distribution of the radiation coming from this material messes with the FLIR's internal assumptions of the object being a black body, rather than this being a geometric problem as you suggest.
Gory details:
the sensor in the FLIR is the same as a ccd camera sensor, except that its sensitivity is windowed between 7.5 and 13um (datasheet PDF here)
the only thing the device can do is count electrons that incoming photons have displaced across some potential barrier. Doing this (which is a measure of joules) effectively computer the integral of spectral radiance across the spectral sensitivity curve of the instrument, over the angle subtended by each pixel, over the area of said pixel and over the exposure time. Assuming that incoming radiation is constant (enough) over time, incoming solid angle and receiving area, the three are divided out and incoming "total" radiance is computed.
Total is in quotes, because usually the spectral responsivity curve is far from flat, and as discussed it only covers some range (7.5-13um in this case).
I assume calibration happens combining the expectations from integrals of Planck's law over this spectral range at a number of given temperatures and actual electron counts divided by exposure time, which is likely non-constant
For what concerns the angle of observation, if the emitter is lambertian (which is a passable approximation for non-shiny, matte looking objects such as dry clay, and a very common one made in most fields except computer graphics) it will emit radiance proportionally to the cosine of the angle between the material normal at the measured location and the direction under which said location is observed. However the observer looking at that location perceived under a given solid angle a surface area element that is inversely proportional to the same angle and the two cancel out (if the area is flat under one pixel).
The plot I posted indicates it probably absorbs 2-5% of the radiation from the plate, per mm of thickness. I just measured the glass on a broken 6L6GC I happen to have and it seems to be approx .75mm thick, so take those numbers down a bit. (half mm would be sqrt absorption). So we're going for "pretty transparent" here
As to the glass getting hot, I'll come to that in my answer to PRR.
Well, I mean no disrespect, and I've read many very interesting posts from you, but do you mind if we look at the evidence on this one, please?
Right, the tube is a cylinder of 38mm diameter and approx 75mm high, so its radiating surface is approximately .009 m^2 (three times as much as the total surface area of the anode). Glass emissivity is .85-.95 (see here) so if it's sitting at 179C it should be emitting just about 18W by radiation alone. That doesn't seem insignificant to me actually.
Different from what I was saying answering JMFahey's message, it's very unlikely that this emission would be lambertian, because the emitting surface is very smooth, so the expectation would be to have most radiation coming off at a normal angle to the surface.
Well, the paper solves the smoothness problem, making the emitting surface closer to lambertian, but even then one should be off in the measurement of radiance by a factor of up to \pi (the cosine integral over a hemisphere). I have not thought it through as to what this means to go back to temperature, likely some kind of inverse Stefan-Boltzmann, i.e. proportional to the fourth root of the temperature in Kelvin would be my guess.
However, the deflection of photons by the glass envelope depends on the wavelength, of course. Judging by this plot it seems the index of refraction of glass in the visible and up to maybe 8um is more or less the same, in the 1.5 to 1ish range, arguably much lower for the 8-10um range. This is all to say that it doesn't seem that IR photons would behave much differently than visible photons in this respect.
If my hunch of this being a fourth square root thing is correct, then the FLIR will receive phothons from the glass emission as well as non-absorbed photons from whatever is behind it. If these are colder, the glass emission will dominate (giving the impression that the instrument can't see past the glass), but if it is the glass that is colder, you should see through it just fine, it's just about which signal drowns the other.
I just haven't thought it through re radiance-to-temperature conversion as what happens as the emission peak moves in the spectrum between a wavelength and another with changing temperature.
hm. don't know what happened, a piece of my post seems to have been lost.
Anyways, I made a couple calculations including convecting heat exchange
Looking at convective transfer data between air and glass it seems that the convection coefficient for "air in the house" is h=10-15 W/m^2K (figures used in architecture to estimate windows heat loss). So the convective heat flow through the envelope should be h*A*\Delta(T). A is ~0.01 so we have one/one and a half watt per 10 deg C difference between envelope and air around it. To move 18W we'd need the envelope at approx 200C (20+180) if it stayed in continuous contact with fresh, room temperature air. If we instead say that the air touching the glass is more like 60C (because it doesn't flow fast enough), the heat exchange rate goes to 14W approx.
Putting the glass radiation and convection transfer mechanisms together we get that glass at 132C radiates away 11.6W and convects away 6.45W. I wonder how one could measure the actual temperature of the glass to verify what's going on here...
Old 1st September 2019, 12:00 PM   #7
trobbins is offline trobbins  Australia
trobbins's Avatar
The tube glass is quite thin, and the plate is circa 400-500C for a 6L6 at rated dissipation (there is a nice assessment of this in RCA 1962), so a minor percentage of plate radiation passes directly through the glass (if you look up the transmission characteristic of common glass to wavelength (there is a nice IRCON app note AN109 on this) and do some mental gymnastics for the wavelength emission spectrum of a circa 500C black body. The plate radiation that gets absorbed by the glass then mostly transfers by convection.
You would need to check your FLIR wavelength response, and compare that to the glass characteristic to see how much the FLIR is seeing the glass as opaque.
Old 1st September 2019, 12:33 PM   #8
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Simple dumm blonde experiment......most literature states that steel will begin to exhibit a red glow somewhere between 400 and 500C, in fact the number 460C is often quoted. So....
Wire up a power supply to a properly connected old tube and crank up the dissipation until the plate begins to glow red.....point the Flir at it and read the number.
I could do the glowing red part easily enough, but I lost my access to a Flir when I left Motorola.
We had a rather nice one with a very expensive lens and mega stable platform for looking at individual transistors on an IC die. It was good for blowing up silicon and other semiconductors on a microscopic scale.......GaN chips will get hot enough to unsolder themselves before they die!
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 1st September 2019, 02:51 PM   #9
Very interesting regarding the GaN chips- GaN chips are rad hard.
All I know is that the tubes get too hot to touch, but this talk about Stphan-Boltzman and black body radiation made me pull out the college physics and materials science textbooks.
Have to agree with TRobbins regarding convection heating.
Old 1st September 2019, 06:57 PM   #10
Sorento is offline Sorento  Europe
Sorento's Avatar
maybe this helps, taken from "RCA 1962 Electron Tube Design"
Plate temperature measurementHide this!Advertise here!
CNC custom aluminum plate, case, heatsink, front plate SunnyCNC engineering Vendor's Bazaar 0 16th September 2017 02:27 AM
nearfield measurement vs listening position measurement pointless?? charlie2 Multi-Way 21 5th November 2015 05:15 PM
Simplified pentode Loftin-White with plate-plate feedback homeskillet Tubes / Valves 17 3rd August 2013 04:58 AM
Dynamic displacement vs resistance vs temperature measurement for ribbon transducer thadman Equipment & Tools 16 22nd December 2009 04:00 AM
Dynamic resistance vs temperature measurement for ribbon transducer thadman Multi-Way 0 3rd December 2009 07:29 PM
Copyright ©1999-2019 diyAudio
