Quick transformer question
Old 20th August 2019, 12:47 AM   #1
Windcrest77 is offline Windcrest77  United States
Default Quick transformer question
For these Antek torroids, would I hook the yellow and white together to make a 200-0-200 center tap transformer? I'll use the variac.
http://www.antekinc.com/content/AS-1T200.pdf
Old 20th August 2019, 01:27 AM   #2
Tjj226 is offline Tjj226
Yes, yellow and white go together to form your center tap.
Old 20th August 2019, 01:37 AM   #3
rayma is offline rayma  United States
Make absolutely certain (with an ohm meter) that the two wires you connect together are from different windings. Otherwise a winding will be damaged and ruin the transformer.
Old 20th August 2019, 03:14 AM   #4
Thanks I was gong to run a few volts ac with the scope to double verify the phases of each winding.
Old 20th August 2019, 03:25 AM   #5
Great idea. To be safe you can use a signal generator set to 60Hz, with 1k resistor in series.
The colors will be correct for phase, but sometimes which pair make up one winding isn't so clear.
Old 20th August 2019, 02:52 PM   #6
After asking this I decided to make the power supply fully dual-mono for L/R channels, rather than the shared CT supply full-wave the schematic specifies. Since this torroid has two secondary wingdings I'll just use a bridge and CLC on each and have two isolated supplies for each stereo channel. With no extra space needed for another transformer. Same for the DC filaments. Might be better separation I suppose (theoretically).
Come to think of it I kind of like having two identical secondary's rather than a center tapped transformer. You have more options, use them separately, in series for a CT, or in parallel to increase the current rating.
I'll have to rework the voltages for a bridge.
Old 20th August 2019, 04:02 PM   #7
Let me know how that goes, I have considered doing the same thing a few times.
Quick transformer questionHide this!Advertise here!
QUICK transformer Question HELP coldcathode Tubes / Valves 5 24th February 2010 06:33 AM
Quick transformer question Brit01 Tubes / Valves 5 23rd July 2009 07:26 PM
Another quick transformer question Hiwatt25 Chip Amps 6 8th February 2008 10:56 AM
Quick Transformer Question krzanik Tubes / Valves 2 17th May 2007 09:15 PM
quick transformer question VictorG Tubes / Valves 2 9th January 2004 09:00 PM
Copyright ©1999-2019 diyAudio
