Glass-ware Aikido 12vac build
Glass-ware Aikido 12vac build Please consider donating to help us continue to serve you.
Old 15th August 2019, 03:15 PM   #1
qguy2000 is offline qguy2000
Default Glass-ware Aikido 12vac build
First off my skills.
I can solder, measure voltages using a meter. I have recapped a Pioneer SX-1050. Troubleshooting skills in non existent. I just replaced parts based on the schematics and or instructions from forums.
I read a lot of good reviews on the performance of the Glass ware 12ac Aikido pre. I am a just a bit concerned about the documentation/schematics that is included in the kit. I have heard that there are several errors on the documentation.
Does anyone know if the documents / schematics / manual has been updated ?
Old 15th August 2019, 03:45 PM   #2
petertub is offline petertub  Sweden
Don't listen to gossip. "I have heard" without sources or other documentation is gossip.
I have good experience of their kits, go for it !
My home is at www.tubular-well.se
Old 15th August 2019, 04:31 PM   #3
rayma is offline rayma  United States
Their kits are very high quality. Study the schematic and parts before starting.
You can post any questions here before assembly.
Old 15th August 2019, 09:34 PM   #4
vconsumer is offline vconsumer  United States
I built one of these. The only error in the documentation was that it suddenly cut off near the end. The parts are all neatly labeled as is the circuit board, so no problems putting everything together.
Old 16th August 2019, 03:04 AM   #5
lavane is offline lavane  United States
lavane's Avatar
I've built a couple Aikido's. I'm pretty sold on them. First I built a 12au7 version, then a 12ax7 version. The one I'm using now uses 6sn7 octals. I'm perfectly happy with the latest one. I've used and built other preamps, but the Aikido is by far my favorite.
Have fun with your build!
Old 19th September 2019, 04:52 PM   #6
I have assembled my unit, this is the 6dj8 Version which requires the 12v ac transformer
target is 80V for B+ and 25.v for heater voltage
These are my measurements
Without Tubes
Voltage across C2 B+ 104v
Voltage across C10 heater 26.6v
With Tubes
Voltage across C2 B+ 93.8
Voltage across C10 heater 19.6
Old 19th September 2019, 04:57 PM   #7
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
In the spirit of DIYaudio … could you include a schematic, so that C₂ and C₁₀ actually can be visualized?
B+ of 104 volts unloaded, and 94 volts loaded does not sound out-of-spec. If there is a resistive hum-filter in the power supply, a –10 V drop is fairly usual. Can't say much about your C₁₀ measurements without a schematic diagram. Capturing with your smart phone would be good enough!
Just saying,
GoatGuy ✓
Burnished unicorn horn circuit design only goes so far. When the magic disappoints, its best to rely on solid maths. Just Saying
Old 19th September 2019, 05:10 PM   #8
Hope this helps
C2 — imgbb.com
c10 - Imgs.info
12vac — imgbb.com
Old 20th September 2019, 08:50 AM   #9
Input voltage is 12.8v
Measured the voltages again without changing anything. I noticed R15 (47ohms) was getting really hot that I could not touch it and it started to smell
I replaced R15 with the physically larger 20 ohm resistor and it gets hot after 30 seconds or so. Without the tubes, R15 does not get hot as much
Voltages after I replaced R15, Tubes installed
Voltage across C2 B+ 94
Voltage across C10 heater 23.4
Voltage across R15 10.8v
Without the tubes, measurements below
Voltage across C2 B+ 103.6v
Voltage across C10 heater 26.8v
Voltage across R15 7.2v
Old 20th September 2019, 02:07 PM   #10
EDIT: I inserted a 2 amp resistor on the secondary and it blows
Glass-ware Aikido 12vac buildHide this!Advertise here!
Anyone build the Glass Ware Aikido amp with Janus shunt regulator? djn Tubes / Valves 13 25th October 2018 06:02 PM
Glass Ware and Pass Enochrome Tubes / Valves 12 31st August 2016 09:14 PM
FS: Broskie (glass-ware) Aikido 12vAC Preamp - fully assembled Metropolis Swap Meet 3 23rd June 2015 02:49 AM
LM3875 (Audio sector) + Aikido 12VAC or Aikido ACF-2? Sodacose Chip Amps 30 28th August 2013 10:28 PM
Glass-ware? mmmalmberg Tubes / Valves 12 19th November 2012 07:54 PM
Copyright ©1999-2019 diyAudio
