Glass-ware Aikido 12vac build
Glass-ware Aikido 12vac build Please consider donating to help us continue to serve you.
Old 20th September 2019, 02:36 PM   #11
Steve Morley is offline Steve Morley  Canada
Do you mean a 2 amp fuse?
Steve
Old 20th September 2019, 02:38 PM   #12
qguy2000 is offline qguy2000
Steve
Yes, 2 amps
I initially did my testing/measurements without the fuse.
Old 20th September 2019, 02:39 PM   #13
I mean 2 amp fuse...
Originally Posted by qguy2000 View Post
EDIT: I inserted a 2 amp resistor on the secondary and it blows
Old 20th September 2019, 02:48 PM   #14
It's possible to blow a 2 amp fuse in the secondary. Fuse the primary side of the power trans with about a 1/2 amp slow blow fuse.
Your voltage readings with the 20 ohm resistor are about correct. Yes this resistor will get warm. You will need a 5 watt resistor here. I used two 51 ohm, 3 watt res in parallel here, equivalent to 25.5 ohm. 6 watt res. Theses still get warm. So if you want it to run cool a 10 watt res ( or 2 5 watt in parallel) might be the best for R15.
See these articles for assembly and test:
Battle of the Cheap Line Stages – Part 1 | Wall of Sound | Audio and Music Reviews
Battle of the Cheap Line Stages – Part 3 | Wall of Sound | Audio and Music Reviews
Battle of the Cheap Line Stages, Part 4 | Wall of Sound | Audio and Music Reviews
Steve
Old 20th September 2019, 02:51 PM   #15
EDIT: or two, 5 watt in parallel
Old 20th September 2019, 02:59 PM   #16
Thanks !!!
This is the resistor that came with the kit, wattage was not stated in the plastic bag that came with it
r15 resistor - Imgs.info
Old 20th September 2019, 03:02 PM   #17
If you spin vinyl and are feeling brave the Broskie Tetra phono pre is a good project.
Fist of five parts detailed here:
DIY All-Tube Phono Preamp Project: It’s on! | Wall of Sound | Audio and Music Reviews
Steve
Old 20th September 2019, 03:09 PM   #18
Tried vinyl a few years ago and found out that I could not live without the skip button
DIY All-Tube Phono Preamp Project: Itís on! | Wall of Sound | Audio and Music Reviews
Steve
Old 20th September 2019, 03:17 PM   #19
Might be a five watt resistor, might only be a three. It will get warm. The ones I used were wirewound so they are "meant" to get hot. If the one with the kit burns up you'll know you need something with a higher wattage rating. As a tip for next time keep this resistor up off of the board about an inch to aid it heat dissipation.
Also, it's a good idea to solder the component leads on both sides of the board whenever possible. I like to keep the large diodes above the board a bit too as they can get a bit warm.
S.
Old 20th September 2019, 03:26 PM   #20
Thanks for all the tips.
Glass-ware Aikido 12vac buildHide this!Advertise here!
Anyone build the Glass Ware Aikido amp with Janus shunt regulator? djn Tubes / Valves 13 25th October 2018 06:02 PM
Glass Ware and Pass Enochrome Tubes / Valves 12 31st August 2016 09:14 PM
FS: Broskie (glass-ware) Aikido 12vAC Preamp - fully assembled Metropolis Swap Meet 3 23rd June 2015 02:49 AM
LM3875 (Audio sector) + Aikido 12VAC or Aikido ACF-2? Sodacose Chip Amps 30 28th August 2013 10:28 PM
Glass-ware? mmmalmberg Tubes / Valves 12 19th November 2012 07:54 PM
Copyright ©1999-2019 diyAudio
