50EH5 Tranformer Question
Old 13th August 2019, 06:47 PM   #1
nikon f is offline nikon f  United States
Default 50EH5 Tranformer Question
I am going to build a 50EH5 amp from this site: http://www.t-linespeakers.org/tubes/SEP_50EH5.html, I will be using isolation transformers. What primary ohm rating should I use for the output transformers?
Old 13th August 2019, 07:47 PM   #2
tikiroo is offline tikiroo  New Zealand
If you follow one of the links on that site it says 2.5-3k primary.
Old 13th August 2019, 08:31 PM   #3
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
The tube datasheet gives an example 1 tube class A amp. 3000 Ohm OT.
However, that will give you a very poor speaker damping factor in pentode mode with no N Fdbk.
https://frank.pocnet.net/sheets/093/5/50EH5.pdf
Old 15th August 2019, 04:16 AM   #4
PRR is offline PRR  United States
PRR's Avatar
Look-up your tube at Frank's.... the factory datasheets tell you good operating conditions.
electron Tube Data sheets - Search
50EH5 Tranformer QuestionHide this!Advertise here!
Magnavox 50EH5 Stereo Amp avincenty Tubes / Valves 18 7th April 2019 03:17 AM
Hiwatt custom tranformer 70v bias question Brianvcskin Instruments and Amps 11 15th March 2016 11:08 PM
SWR Workingpro 10 tranformer kaboom and a dumb question. yustech Instruments and Amps 10 5th January 2016 10:26 PM
Component ID from a 50EH5 Amp booangler Tubes / Valves 4 30th January 2009 11:26 PM
Tranformer question CPX Parts 3 7th February 2005 07:44 PM
Copyright ©1999-2019 diyAudio
