Sanity check on 807 pp amp, before pcb design
Old 13th August 2019, 09:17 AM   #11
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Originally Posted by artosalo View Post
There is GNFB (from output to U4) in the schematic but not very clearly drawn.
Usually smaller than, say 16 dB of GNFB is easy to manage.
Essentially more power with AB2.
AB2 will significantly increase the distortion.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 13th August 2019, 09:24 AM   #12
6A3sUMMER is offline 6A3sUMMER  United States
Agreed,
The MOSFET can produce the required grid current, but the 6.8k grid stoppers will cause lots of clipping at that point.
Old 13th August 2019, 09:44 AM   #13
artosalo is offline artosalo  Finland
artosalo's Avatar
In post #5, he said he was considering having no global negative feedback.
Sorry, I did not notice that. Of course pentode output amplifier needs some sort of NFB, otherwise the audio performance is similar to tube radios from fifties.
No, if well done.
...but the 6.8k grid stoppers will cause lots of clipping...
Sorry, I didn't notice this either. Not 6k8 grid stoppers for AB2 drive, preferably 68 or 6.8 ohms.
Old 13th August 2019, 08:08 PM   #14
heinrichs is offline heinrichs  Denmark
First off, I have no plan of going into ab2 territory, I dont believe that i really need more than 25W.
The reason I put the source followers on, are simply because I want to affect the gain in the ltp as little as possible. And well... I would do something similar on a ss-amp.
About the talk of feedback. I know that my dampning factor will be quite low without feedback, but I am curious to try, simply to hear the effect.
And distortion wise, in my simulations it doesnt get that bad, when i remove the feedback, if I get around 1.3% thd. which isnt that bad.
So is the reason that you guys say that i need gnfb, distortion, dampning factor or something else?
btw. at the moment it runs with approximate 8dB feedback.
And I am going to use some opt from an eico st70.
And thank you all for your inputs it is greatly appreciated.
Old 13th August 2019, 11:38 PM   #15
gregt is offline gregt  New Zealand
I will be interested how it tests and sounds. I like to put small value (22 ohm) fusable resistors on the plate close to the cap and I note that the 807 datasheet also suggest plate resistors of a low value.
Good luck with the build..
Old 13th August 2019, 11:46 PM   #16
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
250V for MOSFETs is too high, you will fry control grids on transients, you need to limit their current on peaks. Better increase the negative voltage, to avoid audible clipping of negative peaks.
Obviously, grid stoppers have too high for A2 values. You may use jumpers instead of resistors on PCB if find later that they are not needed.
Add some dominant pole compensation just in case if you will need it.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old 14th August 2019, 01:12 AM   #17
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by heinrichs View Post
I have played with 6n1p, but as you say, then i cant have any feedback. I have however considered going no global feedback.. My solid state amps are ngfb, and i quite like them.
Don't do that, trust me on this. You might be able to get away with PP pentodes without any NFB if you're using something like the 6V6 or a TV HD type like the 6BQ6. Without gNFB, the 6L6-oids will sound really bad, as this type likes to make higher order harmonics. Even though the STC Report has THD= 1.8%, that's a bit misleading. That's what I measured, however, the residual after nulling out the fundamental looked like a near perfect sawtooth at three times the frequency -- lots of H5 and higher. That leads to a sonic effect as annoying as fingernails on a blackboard. With the 6BQ6, that residual looked like a slightly distorted sinewave: mostly H3 with a trace of H5. Even though the amplitude was higher (THD= 3.0%) the sound was mainly overly "aggressive", but not nasty. Add just enough gNFB to take the "edge" off.
The 6L6-oids need the assistance of NFB in order to sound their best.
But there is no reason to use a power mosfet that is able to deliver severel amps in this position. I mainly used it, because I have some of them. But a quick glance at mouser showed that I should be able to find a suitable replacement with sub 100pF input capacitance. And that will solve the drive problem.
I have also considered just using a 6n1p as a cathode follower instead of a fet. Intuitive it just seems better to use a fet in that position. Maybe I should just make 2 boards and compare them. All these options.... I love it, but sometimes it would be nice with a simpler hobby
Six of one; half dozen of the other. The 807 isn't a hard load, and a cathode follower will work as a grid driver. Grid drivers also allow a bit of Class AB2 so you will get a few more watts over the design nominal spec. The main advantage to a MOSFET here is one less hole to drill. Suggestion: get rid of those 6K8 grid stoppers. You don't need them since the source impedance is quite low, and serves to load the grids. I would add 1K5 screen stoppers. The 6L6-oids like making snivets, and a screen stopper is the only way to prevent that, as the beam formers are internally connected, and so can't have positive bias applied.
The voltage divider for the screens is inadequate. The screen current varies between 5.0mA (no signal) to 19mA (max signal) per 807. The voltage divider, as is, is a 304.62V source in series with 5K08R. The voltage will vary between 309.2V (too high) and 166.96. You need to stiffen the divider for a heavier load, or replace it with an active voltage regulator, or gas regulators: three VR-90 types in series will get the job done. (Probably why the STC Report recommended V22= 270V.). The VR-90 can pull 40mA, so setting them up for a standing current of 35mA should be OK, and a helluvan improvement over a voltage divider.
Transistors have ratings; vacuum tubes have guide lines
Old 14th August 2019, 01:18 AM   #18
Anatoliy Lisovskiy
Wavebourn's Avatar
Since he already has to drill holes for MOSFETs, one more for a source follower for screen grids would not hurt. Either with shunted by a cap voltage divider, or even with a Zener string how I routinely do.
!!!Warning!!!
Old 14th August 2019, 03:35 PM   #19
Mark Tillotson is offline Mark Tillotson
You can share a single divider chain to bias both MOSFET gates.
Drive the input stage constant current source from 0V, not 250V, then the resistors can run far cooler...
You lack a discharge cap on the input capacitor, so it will hold voltage when unplugging a source. Suggest move the 1M to the input jack, replace the 1M with 47k standard input load resistor. This will reduce noise when the input is unplugged.
Old 14th August 2019, 04:05 PM   #20
baudouin0 is online now baudouin0
With 400pf of gate source cap the mosfet will just couple the output of the first stage straight to the grid of the output at HF. You will find the mosfet is making no difference. You could use an emitter follower. You only need a few volts on the collector as the grid only needs to go just above 0v. This would reduce power dissipation the the semiconductor. Maybe 100k on the anodes is too high. Try simulation at 10KHz sinewave.
Sanity check on 807 pp amp, before pcb designHide this!Advertise here!
Sanity Check (Peerless 830986 design) fiatlux Full Range 4 23rd January 2018 12:46 PM
GM70 SE direct coupled sanity check 1st design speedy6963 Tubes / Valves 12 9th January 2018 08:38 AM
Horn Design - Sanity Check deiksac Multi-Way 121 12th October 2008 08:09 AM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright ©1999-2019 diyAudio
