A Tube amp without coupling capacitors? Possible?
Old Yesterday, 02:49 PM   #211
Keit is offline Keit  Australia
Originally Posted by lechuck View Post
This is an example of a Norton shifter:
The circuit as shown is likely to exhibit poor treble response, and if overall neg feedback is used, is very likely to oscillate.
A few picofarad (if next tube is a pentode or tetrode) to 20pF or so (if next tube is a triode) across the level shifting resistor will compensate, so the fix is quite simple
Another option would be to use sweep tubes (EL509..) and drive them on the screen grid (G2)
The screen grid used as a control grid is insensitive and usually not as linear as the true control grid. It draws power too, complicating the design of the previous stage.
A Norton shifter is not a single device and can be built with components that where already available in the late 50's, early 60's.
All you need for the CCS is a small pentode (eg 6AU6 or 6BA6, pentode half of a triode pentode) and three resistors. Nothing could be simpler - except using a neon tube as coupling device (but neons are noisy, have a short life, and can exhibit small voltage jumps in old NOS devices and in neons intended as indicating lamps.)
Old Yesterday, 03:07 PM   #212
jhstewart9 is offline jhstewart9  Canada
jhstewart9's Avatar
Default DC Amplifiers
The DC Amplifiers I built were most all in industrial & scientific applications, no one had to listen to them.Many were in the regulated Power Supplies for both constant voltage & constant current apps.. When good silicon rectifiers became available they were the obvious choice for the rectifier.
The largest was a monster 4.5 KV, One Amp CV thing. The iron was all Hammond, built to order for us. One of the features of the whole thing for which I'm thankful to Prof Anderson for was an SYA setup. Save Your ***, the source relay contacts welded together on contact, they did not release on shut down. There was a very loud explosion as the SYA device operated.
By 1965 there were quite a few multi layer silicon devices on the market. But nothing that would shift something like 100V CC or more. All easy to do now, we are in an age of plenty.
Old Yesterday, 08:51 PM   #213
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Originally Posted by jjasniew View Post
From the suggested article; "Note; even if the measured performance appears flat, our ears are quite capable of distinguishing micro-effects that limit the potential musical beauty of an amplifier and that is, I assert, the point of this hobby - so long as we are having fun"
Right, and that micro-effects are dynamic, while measurements are static and averaged.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
Old Today, 03:08 AM   #214
If its your hobby, that's fine - it's your money and it's not hurting you or anyone else.
But any engineer who designs audio equipment with a claim to quality sound professionally or for home and friends should read Eberhard Zwicker's book "Psych-Acoustics" (Springer Verlag).
Zwicker spent a lifetime researching just what our ears can and cannot do. The book (3rd edition) is about 450 pages of data, and is effectively a very detailed technical specification of the human hearing system. And when you have read and digested Zwicker's book, you will be well aware that the statement quoted by jjasniew is complete nonsense.
And if you are not convinced by the book that all aspects of human hearing can be measured and reduced to data, you can obtain the CD of test signals and try it on your self, if you have a high quality reproduction system. Or, if you have sufficient electronics knowledge and test equipment, you can reproduce Zwicker's tests.
There is NO defect in electronic audio reproduction that cannot be measured. None. But some of the measurement/test techniques required are unknown in much of the audio community.
Old Today, 04:48 AM   #215
Anatoliy Lisovskiy
Wavebourn's Avatar
!!!Warning!!!
A Tube amp without coupling capacitors? Possible?Hide this!Advertise here!
Teflon Coupling Capacitors 0.1 0.2uF for tube Amps Perfectusaudio Parts 32 6th April 2019 09:48 PM
Coupling capacitors sb****33 Tubes / Valves 15 29th October 2015 02:35 PM
Coupling capacitors ChristianThomas Solid State 12 17th May 2012 01:06 PM
Coupling capacitors lazzer408 Instruments and Amps 20 12th November 2011 05:19 PM
AC coupling capacitors... Frazzled Solid State 8 30th June 2004 06:28 AM
Copyright ©1999-2019 diyAudio
