6CA7 Triode G2 AND G3 - what to do?
Old 9th August 2019, 04:31 AM   #1
jjasniew is offline jjasniew  United States
Default 6CA7 Triode G2 AND G3 - what to do?
I recently learned that a 6CA7 has a "user assignable" G3, which in most other power output tubes is internally connected to the cathode. The Tubecad page I recently visited shows a 6CA7 triode connection circuit where both G2 and G3 are connected to the plate via different value resistors. Is this optimal?
When browsing for full range speaker cabinet designs, I stumbled on a triode connection that used an amply bypassed string of 6.3V zener diodes (adding up to ~30V) for the G2 connection to plate - with the corresponding claim that this was the only way to do it properly. Most use resistors....
I tried that idea using a TL431 with some capacitive bypass, set to 27V. It works, with nothing on fire, and the tube pairs seem to DC bias more closely using the shared control as designed by the OEM. Sounds OK. Was using 500 Ohm resistors, but those didnt have anywhere near a 27V drop across them as I recall.
Let's say this constant voltage drop from the plate idea for G2 is actually really good. What would be as appropriate for G3 - since, as a 6CA7 user you're free to connect it as you wish? JB on Tubecad connects it through a 1K resistor to plate, while he connects G2 through 100 ohms. Thanks for any input / discussion!
Joe Jasniewski - PC>Aune T1>JD1301 LM1875 chip amp>OB Lii Audio F15s
Old 9th August 2019, 04:12 PM   #2
kodabmx is offline kodabmx  Canada
Spreading triode love.
Some sheets say to tie it to cathode or ground, some say to tie it to plate for triode. Both work.
I read somewhere once that someone had found a lowered distortion characteristic by running G3 at about 7V. No idea where now though. It was years ago.
Old 9th August 2019, 05:27 PM   #3
So it sounds like G3 could be anywhere voltage wise between cathode and plate. That narrows it! Now, should it follow the plate voltage or stay fixed; i.e hang with the plate or hang with the cathode? ;')
Old 9th August 2019, 05:33 PM   #4
Hanging out with the cathode is the safest bet. That's how almost all other pentodes/KTs are made, right?
Old 9th August 2019, 06:04 PM   #5
Alllensoncanon is offline Alllensoncanon  United States
You properly already knew this. If someone down the line put in a 6L6GC or a KTxx just to see how it sound, there will be a short (if diode are used or the resistant of the G3-Plate resistor) between plate to cathode. Lets say plate voltage is 400V and that G3 to plate resistance is 1K, and Vk = 40V, that will be (400-40)/1000 or 360mA consuming 130W.
Old 9th August 2019, 07:44 PM   #6
6A3sUMMER is offline 6A3sUMMER  United States
Some smart manufacturers of 6L6GC, 5881, KT66, and KT88 amps tie pins 1 and pin 8 together . . . just for the tube rolling enthusiast who puts in a 6CA7 or EL34 (without checking first).
#1. Watch out for a metal 6L6, whatever the cathode voltage is (pin8), the metal cover (pin 1) will be at that voltage. And some KT88 and KT66 manufacturers insist on connecting the metal shield to pin 1 (so you also get the cathode voltage on the metal shield. If it is the top tube in an SRPP output stage, watch out!
#2. Build a 6CA7 or an EL34 amp that ties the suppressor grid (pin 1) to the plate. Watch what happens when a tube roller puts in a metal 6L6, KT66, or KT88, and touches the metal shield.
I call #1 and #2 above the "surviving spouse syndrome".
Old 9th August 2019, 10:32 PM   #7
PRR is offline PRR  United States
PRR's Avatar
That would be Triode mode. Is that what you want??
The effect of each grid is less the further out from the cathode. G3 has very small effect but it deters secondary electrons and violent Tetrode action at low plate voltage.
For Pentode, G2 goes to a high voltage and G3 goes to a low voltage. All the small power pentodes expect you to tie G3 to cathode. Large deviation seems to have little effect until Vg3 is a large fraction of Vg2.
Pete Traynor (guitar amp pioneer) tried G3 to a significant negative voltage, under the theory that this would reduce the damage when his hot-rodded amplifiers were pushed LOUD. 40+ years later my impression is that the effect is insignificant.
And there is the Other Problem, different similar tubes using the same pin for different things, and other tubes potentially blowing-up the amplifier. I have tried 7027(6CA7) G3 via 470k to cathode, so if it got strapped to G2 by a different tube nothing died. It worked in quick bench-tests with 'right and wrong' tubes. I could not measure any significant voltage on the 470K (so G3 current is small, as we might expect for G3 low). But perhaps extended abuse would find a problem with that theory.
There are Transmitter tubes where G3 is optionally tied to +60V for some unclear reason. But these tubes and their uses are different from our little bottles.
Old 10th August 2019, 04:31 AM   #8
Yeah, Triode is what I'm doing with the 6CA7 based Sophia amp. Based on the discussion / information here, I'll leave the G3 as-designed by Sophia. I'll also remember to check for that pin 1 to 8 tie, next time I have the bottom cover off. Thanks!
Any comment on the ~30V solid state drop from the plate for the G2, for triode operation? I expect that's much different than a resistor and it would be interesting to know in what ways. (yeah, like how much worse...) The amp seems to sound OK this way, but, being a 62 yr old neophyte at this, these old ears can still learn a thing or two about what sounds "right".
Old 19th October 2019, 07:44 PM   #9
catalin gramada is offline catalin gramada  Romania
Just tried JJ 6CA7 in triode mode for a bass guitar project with a 2k OT at 450V. Get almost identical output voltage but strong damping factor is achieved with g2 and g3 to the plate in respect with more common approach g3 to cathode.
Old 20th October 2019, 05:51 AM   #10
Wavebourn is offline Wavebourn  United States
Anatoliy Lisovskiy
Wavebourn's Avatar
Connect it to anode. It will be slightly better than to cathode. Insignificant, though, but if the tube is triode connected, there is absolutely no point connecting G3 to cathode, if it is not connected internally.
!!!Warning!!!
Single Ended Class-A-Holism is addictive!!!
6CA7 Triode G2 AND G3 - what to do?Hide this!Advertise here!
Replacing 6CA7 with 6L6 babadockia Tubes / Valves 11 6th June 2019 09:23 PM
Need Help with PSVANE 6CA7-T sdcz Tubes / Valves 13 21st October 2013 06:33 PM
Anyone tried the EH fat bottle 6CA7? rcavictim Tubes / Valves 6 23rd October 2004 11:08 PM
Best 6CA7? cadman Tubes / Valves 4 8th September 2004 03:29 AM
Triode curves for 6CA7, KT88 and 6550 NickC Tubes / Valves 2 26th February 2003 02:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
