Kofi Annan in: "Tube Amp for Multi-Way Speakers"
Old 29th October 2019, 03:07 AM   #151
Kofi Annan is offline Kofi Annan  United States
Kofi Annan's Avatar
Originally Posted by Adolf Corkscrew View Post
That's actually a quite nice response for a 10kHz square wave. I wouldn't worry. The slight resonance - if I read your scope trace right - seems to be at around 50kHz and well damped, so if the amplifier is otherwise stable I wouldn't do anything.
You could measure the amp to other impedances, that might give a different response. Maybe a 47 ohm resistor instead of an 8 ohm dummy load. And try a 2,2F cap in parallel with the 8 ohm dummy and see if the amplifier is still stable. Some overshoot with a cap in parallel with the resistive dummy load is to be expected, but the amplifier should still be stable. If this is true, don't worry.
I'll do a little more measuring tomorrow and post the results. It honestly sounds so good to me that I'm inclined to leave it alone.
The amp looks great!, and from your description it sounds great as well. Great job!
Thanks, Scott. Really appreciate all your help.
It's still nagging me that I have 6.53V on the heaters instead of 6.3. Should I be worried about it?
Kofi
Old 29th October 2019, 01:27 PM   #152
scott17 is offline scott17
Great. That's only ~3.5% high, that's fine. I believe accepted close tolerance is +/- 5%.
Old 29th October 2019, 01:49 PM   #153
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Try NFB from the 8 Ohm output tap also
Old 29th October 2019, 11:41 PM   #154
Adolf Corkscrew is offline Adolf Corkscrew  Finland
Kofi
That's a non-issue. Well within tolerances. Stay under 6,7 volts and it's A-OK.
Old 30th October 2019, 12:01 AM   #155
kevinkr's Avatar
Check at high typical line for your area and if you are under 6.7V or so you should be fine.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Kofi Annan in: "Tube Amp for Multi-Way Speakers"Hide this!Advertise here!
Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" Kofi Annan Tubes / Valves 138 25th February 2019 06:46 PM
Kofi Annan in: "You Can't Spell 'Annan' Without Vancouver!" Kofi Annan The Lounge 8 6th April 2013 10:48 PM
Kofi Annan in: "Speakers for Baby Huey" Kofi Annan Full Range 6 14th November 2011 06:02 PM
Kofi Annan in: "Kofi's Baby Huey" Kofi Annan Tubes / Valves 181 4th June 2011 05:58 PM
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 06:19 PM
Copyright ©1999-2019 diyAudio
