Kofi Annan in: "Tube Amp for Multi-Way Speakers"
Kofi Annan in: "Tube Amp for Multi-Way Speakers" Please consider donating to help us continue to serve you.
Old 18th October 2019, 07:51 PM   #121
Kofi Annan is offline Kofi Annan  United States
Kofi Annan's Avatar
Found it!
I started wiggling stuff and found that when I wiggled the plate connection to the OPT the resistance started to jump around. Turns out a Stupid Solder Blob That Made Problems was the culprit.
Finally got all the solder wicked away and am beginning to hook everything back up for testing.
FAULT #1 ELIMINATED.
KOFI
Old 18th October 2019, 08:05 PM   #122
scott17 is offline scott17
Ah ha! Good catch.
I haven't thought it through too carefully, but that may be the reason for the differing readings-to-ground for your screen taps. You were reading through varying lengths of windings. With just one plate connection "shorted" to ground, the problem would show up on both OTs since the B+ connection is common to both.
I'm sure you'll look carefully, and take the readings again, but where there is one solder blob there may be...
Old 18th October 2019, 08:36 PM   #123
The 80R dropping resistor in your power supply will be dissipating ~10W, so you probably want to use at least a 30W chassis mount or maybe (3) 250R-10W in parallel.
Old 18th October 2019, 10:07 PM   #124
Kofi Annan's Avatar
And we're up and working! Yes!
Thanks to everyone!
PHASE 1: COMPLETE
Old 18th October 2019, 10:11 PM   #125
Kofi Annan's Avatar
Funny Kofi Story:
So, I wasn't getting any output from one of the channels initially. Looked like signal was going in but not getting out. Couple hours roll by and I can't for the life of me...
Then I went to swap the outputs to see and I noticed that I DID NOT STRIP THE PLASTIC OFF THE SPEAKER CABLES.
Yikes, Kofi. That was a bad one.
Kofi
Old 18th October 2019, 10:36 PM   #126
kevinkr's Avatar
OMG.. LOL Glad however that you found it...
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th October 2019, 11:22 PM   #127
Glad you've got it working. Yes, that unterminated output could have been bad.
Old 19th October 2019, 02:38 PM   #128
Lingwendil is online now Lingwendil  United States
Lingwendil's Avatar
Originally Posted by Kofi Annan View Post
Funny Kofi Story:
Kofi
6SN7 Push-pull Flea Amplifier PCB files are now available!
Old 20th October 2019, 03:21 PM   #129
Kofi Annan's Avatar
OK-- question for the council:
So, I need to drop about 30 - 50 volts to hit a supply voltage of around 300VDC to 320VDC and I'm running into some space restrictions in the chassis.
I'm sure I could drop the B+ by lowering the first cap to around 10uF or so (guessing at the value for the moment), but would removing the final filter cap be an option (see schematics attached)?
Thoughts?
Kofi
Old 20th October 2019, 03:52 PM   #130
I'd leave the final cap in place. You could reduce the first capacitor to ~100uF to minimize the initial turn-on surge, and use something like 25R-10W in each leg of the PT secondary before the rectifier.
Kofi Annan in: "Tube Amp for Multi-Way Speakers"Hide this!Advertise here!
Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" Kofi Annan Tubes / Valves 138 25th February 2019 06:46 PM
Kofi Annan in: "You Can't Spell 'Annan' Without Vancouver!" Kofi Annan The Lounge 8 6th April 2013 10:48 PM
Kofi Annan in: "Speakers for Baby Huey" Kofi Annan Full Range 6 14th November 2011 06:02 PM
Kofi Annan in: "Kofi's Baby Huey" Kofi Annan Tubes / Valves 181 4th June 2011 05:58 PM
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 06:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
